2014 Toyota Camry L won't start
wramsey12
Member - Posts: 26
Posted: September 02, 2015 at 3:00 PM / IP Logged Link to Post Post Reply Quote wramsey12
I had installed a Remote starter into my Camry a while back with a couple members help (thanks kreg357 and Howie II) Everything was working fine until I noticed a wire had come loose. Not sure how this happened but it did so I put it back. This wire was the lt green wire for the ignition switch pin 3. After putting it back now my car won't start at all. I get no lights or anything and I'm hearing a clicking noise all the time unless I put my key in the ignition. Any help is much appreciated.
Posted: September 02, 2015 at 5:12 PM / IP Logged Link to Post Post Reply Quote howie ll
You might have a drained battery.
That or check for a loose connection.
Do a voltage check, ground point to all the fuses.
wramsey12
Member - Posts: 26
Posted: September 02, 2015 at 10:04 PM / IP Logged Link to Post Post Reply Quote wramsey12
I took a test light out and got nothing from any fuses or the battery so I took out multimeter and my battery is reading dead....not sure how that happened and I should have thought to check that first. Tomorrow I'm gonna see about getting a jump and will go from there. Thanks howie for the reality check.
wramsey12
Member - Posts: 26
Posted: September 03, 2015 at 7:30 PM / IP Logged Link to Post Post Reply Quote wramsey12
Went to jump the battery today and no luck. Everything inside comes on but the battery wouldn't start the car. Took it loose and had it tested and 1 cell is out and it's definitely dead. Thanks again howie.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
