1933 Ford Hot Rod Audio install
upstateny
Posted: September 04, 2015 at 9:47 PM / IP Logged Link to Post Post Reply Quote upstateny
Hi, first timer here that doesn't know much about car audio :(.
I'm going to install 4 JL Audio Evolution C2 6.5 100w Coaxial speakers, 1 JL 8w3 300 watt Vented enclosure MicroSub™ slot-ported enclosure , a JLA-XD700/5 700 watt amp and a Kenwood KEN-KMMBT312U USB / Bluetooth receiver.
The 1993 Ford is a 2 seater coupe. One foot behind the 2 seats is a "firewall" the full width of the car (essentially 1/2 inch thick wood covered with leather). The 4 speakers will be installed on that rear firewall pointed forward towards the 2 seats and into the car's cabin. Behind that rear firewall, there is a 10" deep open space, then there is another firewall, and behind that firewall is the car's trunk.
So I have a nice 10" deep by 3 feet high, by 4' feet wide "hidden space" in which to install the amp and JL sub-woofer. Also, between the trunk and that hidden space I have an 4' wide 10" H hinged access door so I can access the amp and sub woofer from the trunk. The car's battery is also located in that hidden space.
Due to aesthetics, I do not want to install any speakers in the doors or kick panels of this car. I realize I may suffer some audio goodness as a result of this decision.
My questions are simple: a local stereo shop recommended that the single sub-woofer be installed in that hidden space. I assume the 300 Watt woofer would point forward towards the cabin of the car ?
Also, give that the sub-woofer will be installed behind the car seats in my hidden space, will the bass sounds be able to penetrate the 1/2 wood firewall ?
Thank you all in advance for any ideas/comments you have.
Joe
DYohn
Moderator - Posts: 10,741
Posted: September 07, 2015 at 10:51 AM / IP Logged Link to Post Post Reply Quote DYohn
While I can't say if the gear you have chosen is the best option, the installation location sounds ideal for a subwoofer.
upstateny
Posted: September 07, 2015 at 2:38 PM / IP Logged Link to Post Post Reply Quote upstateny
Ok, I feel "ok" with the equipment selection as it's a small car and it'll have plenty of volume. Thank you very much.
Joe
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
