2015 Nissan Note Alarm/Remote Start, Stereo Wiring
puertorico
Posted: October 08, 2015 at 8:29 AM / IP Logged
I need this diagram for the installation of an alarm, nissan note 2015 thanks
Nestor PR
tonanzith
Gold - Posts: 593
Posted: October 10, 2015 at 9:57 PM / IP Logged
2015 Nissan Versa Note      DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     pink (40A)     +     ignition switch, white 6 pin plug, pin 3
Second 12 Volts     N/A
Starter     white     +     ignition switch, white 6 pin plug, pin 2
Second Starter     N/A
Ignition     gray     +     ignition switch, white 6 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     yellow     +     ignition switch, white 6 pin plug, pin 4
Second Accessory     lt. blue     +     ignition switch, white 6 pin plug, pin 5
Third Accessory     N/A
Keysense     yellow     +     key switch or BCM above driver kick, white 40 pin plug, pin 37
Data Bus     pink (clock); lt. green (data)     data     NATS ant amp or BCM above driv kick, white 40 pin plug, pins 21, 25
     The security light is RED / yellow (-) at the BCM above driver kick, white 40 pin plug, pin 23.
Can Bus High     blue     data     data link conn or BCM above driv kick, white 40 pin plug, pin 39
Can Bus Low     pink     data     data link conn or BCM above driv kick, white 40 pin plug, pin 40
Can Bus Sw     N/A
Power Lock     gray     -     BCM above driver kick, white 40 pin plug, pin 12
Power Unlock     brown     -     BCM above driver kick, white 40 pin plug, pin 13
Lock Motor     lt. blue     5 wire     BCM above driver kick, white 15 pin plug, pin 14
Driver Unlock Motor     green     5 wire     BCM above driver kick, white 15 pin plug, pin 1
Passenger Unlock Motor     green     5 wire     BCM above driver kick, white 15 pin plug, pin 13
Parking Lights (-)     N/A
Parking Lights (+)     red to blue     +     driver kick, white 24 pin plug, pin 3
Hazards     orange     -     BCM above driver kick, white 40 pin plug, pin 29
Turn Signal (Left)     purple     +     BCM above driver kick, black 15 pin plug, pin 9
Turn Signal (Right)     white     +     BCM above driver kick, black 15 pin plug, pin 8
Headlight     blue (L); pink (R)     +     headlights or underhood fuse box, brown 8 pin plug, pins 6, 8
AutoLights     N/A
Reverse Light     lt. blue to yellow/blue     +     driver kick, white 16 pin plug, pin 4
Left Front Door Trigger     lt. blue     -     BCM above driver kick, black 15 pin plug, pin 4
Right Front Door Trigger     orange     -     BCM above driver kick, black 15 pin plug, pin 5
Left Rear Door Trigger     white     -     BCM above driver kick, black 15 pin plug, pin 3
Right Rear Door Trigger     brown or lt. green     -     BCM above driver kick, black 15 pin plug, pin 2
Dome Supervision     red     -     BCM above driver kick, white 15 pin plug, pin 5
Trunk/Hatch Pin     pink     -     BCM above driver kick, black 15 pin plug, pin 7
Rear Glass Pin     N/A
Hood Pin     N/A
Trunk/Hatch Release     (locks/unlocks along with doors)
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     gray (driver door key lock)     -     BCM above driver kick, white 40 pin plug, pin 8
Factory Alarm Disarm     white (driver door key unlock)     double -     BCM above driver kick, white 40 pin plug, pin 7
Disarm No Unlock     (see factory alarm disarm)
Trunk Alarm Shunt     N/A
Tachometer     blue, orange, green, or red     ac     any fuel injector, black 2 pin plug, pin 2
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     lt. green     +     clutch switch, brown 2 pin plug, pin 2
Fuel Pump     brown to green     +     driver kick, gray 16 pin plug, pin 5
Rear Defroster     green     -     BCM above driver kick, white 40 pin plug, pin 10
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     yellow     5 wire     LH heated seat switch, white 6 pin plug, pin 5
Right Front Heated Seat     brown     5 wire     RH heated seat switch, brown 6 pin plug, pin 5
Speed Sense     lt. green     8-Pulse     radio, white 20 pin plug, pin 18
Brake Wire     lt. green     +     brake switch or BCM above driver kick, white 40 pin plug, pin 9
Parking Brake     lt. blue     -     parking brake switch, black 1 pin plug, pin 1
Horn Trigger     red     -     horn switch, yellow 6 pin plug, pin 3
Wipers     lt. green (L); gray (H)     +     wiper motor or underhood fuse box, brown 12 pin plug, pins 1, 2
Left Front Window (Up/Down)     red - lt. green     A     power window main switch, white 16 pin plug, pins 8 - 11
Right Front Window (Up/Down)     white - purple     A     driver kick, door harness, white 12 pin plug, pins 2 - 3
Left Rear Window (Up/Down)     gray - orange     A     driver kick, door harness, white 12 pin plug, pins 10 - 11
Right Rear Window (Up/Down)     lt. green - red     A     driver kick, door harness, white 12 pin plug, pins 12 - 1
Sun Roof (Open/Close)     N/A
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     yellow     +     radio, white 20 pin plug, pin 19
Radio Ground     (chassis, base audio); blk/wht (except base audio)     -     radio, white 20 pin plug, pin 20
Radio Ignition     white     +     radio, white 20 pin plug, pin 7
Radio Illumination     lt. grn/red (prkng lghts); blk (dmmr, except navi)     +,-     radio, white 20 pin plug, pins 9, 8
Factory Amp Turn-on     N/A
Power Antenna     black     +     radio, gray 3 pin plug, pin 1
Left Front Speaker (+/-)     gray - pink     +,-     radio, white 20 pin plug, pins 2 - 3
Right Front Speaker (+/-)     orange - purple     +,-     radio, white 20 pin plug, pins 11 - 12
Left Rear Speaker (+/-)     white - red     +,-     radio, white 20 pin plug, pins 4 - 5
Right Rear Speaker (+/-)     blue - yellow     +,-     radio, white 20 pin plug, pins 13 - 14
Center Channel (+/-)     N/A
Subwoofer (+/-)     N/A
Aux. Audio Input Left (+/-)     yellow - green     +,-     radio, wh 32P plg, pins 18-2; wh 8P plg, pins 4-2
     On models with navigation, they are at the radio, white 24 pin plug, pins 10 - 11.
Aux. Audio Input Right (+/-)     blue - green     +,-     radio, wh 32P plg, pins 1-2; wh 8P plg, pins 3-2
     On models with navigation, they are at the radio, white 24 pin plug, pins 12 - 11.
RSE Video (+/-)     yellow - (shield) (rear/around view camera video)     +,-     radio, wh 32P plg, pins15-16; wh 24P plg, pin16-15
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     (built into radio)
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     double DIN center of dash
Left Front Speaker     6.5 left front door
Left Front Tweeter     N/A
Right Front Speaker     6.5 right front door
Right Front Tweeter     N/A
Left Rear Speaker     6.5 left rear door
Left Rear Tweeter     N/A
Right Rear Speaker     6.5 right rear door
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer     N/A
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio)
Gary Sather
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
