Horn hot wire, 2012 Dodge Ram 2500
sumneree
Posted: October 26, 2015 at 4:54 PM / IP Logged Link to Post Post Reply Quote sumneree
Wiring a set of hornblasters air horns to a 2012 Dodge Ram 2500. Could someone please tell me which wire in the steering column loom is the horn wire?
thanks
Ernie
Platinum - Posts: 13,666
Posted: October 26, 2015 at 5:02 PM / IP Logged Link to Post Post Reply Quote i am an idiot
In the steering column harness it will be a negative wire that will drive a relay. If you need a "Hot" wire you will have to catch that under the hood between the horn relay and the horn itself.
Give me a minute and I will tell you what color the horn wire is in the column harness.
Horn     DARK GREEN/ VIOLET     (-)     IN HARNESS AT STEERING COLUMN
sumneree
Posted: October 26, 2015 at 5:06 PM / IP Logged Link to Post Post Reply Quote sumneree
Awesome! I sure appreciate it. sOunds like I will need to pull from the horn itself though. Need a positive to run the air solenoid.
Posted: October 27, 2015 at 4:18 AM / IP Logged Link to Post Post Reply Quote howie ll
No you don't too much current required, you can either pick up that wire where Mr. I states or it's probably feeding the OEM horn relay under the hood feed another relay from that wire, separately fused.
Never seen a set of air horns that didn't come with a relay.
Or use the factory relay output pick up at OEM horns or relay and increase your OEM horn fuse rating.
First idea safer and failsafe.
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
