A bit confused on wiring, viper, 03 suburban
chevyguy86
Member - Posts: 14
Posted: November 12, 2015 at 10:33 PM / IP Logged Link to Post Post Reply Quote chevyguy86
So I currently bought a viper 5706v with a dball2 for my 03 suburban and want to wire in d2d this is my first car alarm/rs install I have found a lot of good info through this site but I'm still a bit confused as there are two sets of of both ignition 1 and ignition 2 and I'm unsure which to use and where and also to clarify I only use the wires described in the dball diagram that are solid nothing else? Any help is appreciated thanks
I may not be perfect but at least I drive a Chevy
prdjr165
Copper - Posts: 293
Posted: November 13, 2015 at 2:51 AM / IP Logged Link to Post Post Reply Quote prdjr165
connect your wires exactly like the DBALL2 diagram-use only the solid black lines for D2D..
Platinum - Posts: 7,783
Posted: November 13, 2015 at 4:45 AM / IP Logged Link to Post Post Reply Quote kreg357
As prdjr165 says, follow the DB-ALL2 guide.  All the blue dashed lines / connections are via the D2D harness.
The Viper can handle most of the vehicles main ignition circuits:
Pink to Pink
Pink/White to White
Orange to Orange
Violet to Yellow ( vehicle side )
Green to Yellow ( key side )
Red, RED / White, RED / Black to +12V constant
You will need an external 30/40 Amp SPDT relay with harness and 25 Amp in-line fuse if you find you need to power the Brown ACC2 circuit during remote start.
davep.
Gold - Posts: 641
Posted: November 13, 2015 at 9:58 AM / IP Logged Link to Post Post Reply Quote davep.
In my endeavor to make my installs as clean as possible, I've been tapping one of the red Viper wires after one of its fuses for the external ACCY relay. There is very little load on the Brown Accy2 wire in a GM. It's only the radio and wipers,; the additional load on the Viper 30A fuse is negligible.
chevyguy86
Member - Posts: 14
Posted: November 14, 2015 at 12:53 PM / IP Logged Link to Post Post Reply Quote chevyguy86
Okay will do thank you for replying
chevyguy86
Member - Posts: 14
Posted: November 14, 2015 at 1:19 PM / IP Logged Link to Post Post Reply Quote chevyguy86
Okay one more question I have two 12v Constant wires on the ignition loom under the dash that are red and RED / white so do I join the RED / black with one of the red and RED / white coming from viper going to these under dash?
chevyguy86
Member - Posts: 14
Posted: November 14, 2015 at 1:25 PM / IP Logged Link to Post Post Reply Quote chevyguy86
Also key side I assume is what's under dash so where would I look for the yellow wire vehicle side to attach the green wire thanks you all have helped a ton already
chevyguy86
Member - Posts: 14
Posted: November 14, 2015 at 3:25 PM / IP Logged Link to Post Post Reply Quote chevyguy86
Then brake switch is the brown wire on the 25 pin connector right? Also looks like either the white or white brown off the 6 pin goes to the bcm for parking lights which one should I use
chevyguy86
Member - Posts: 14
Posted: November 14, 2015 at 10:35 PM / IP Logged Link to Post Post Reply Quote chevyguy86
Ok so I found the same r/s I used on the site was an 05 siverado but should be the same says the RED / white and RED / black both go to the red and and the red goes to the RED / white and the connections for the 24 pin I'm not hooking up the orange acc with relay or Hood pin switch is this okay here's the link of what I was looking athttps://www.the12volt.com/installbay/forum_posts.asp?tid=138578&tpn=3#reply
chevyguy86
Member - Posts: 14
Posted: November 14, 2015 at 10:38 PM / IP Logged Link to Post Post Reply Quote chevyguy86
Also green and violet also go into the yellow is this right?
Page of 3
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
