Viper 4105V Remote Starter in 2006 Toyota Camry
dsesolinc
Member - Posts: 8
Posted: November 15, 2015 at 8:52 AM / IP Logged Link to Post Post Reply Quote dsesolinc
I am not following what you are telling me.
The "input" from the vehicle, I am currently using is (+) Green.
If I understand the DirectWire wiring reference correctly, then the "Output", on the White wire is also POS since it is based on the input. There is only one "Output" wire so my assumption is that its' polarity is based on the polarity of the input.
Am I incorrect in my understanding.
dsesolinc
dsesolinc
Member - Posts: 8
Posted: November 15, 2015 at 8:53 AM / IP Logged Link to Post Post Reply Quote dsesolinc
I don't know how to change the "Output" polarity on the Viper side. If that is possible
dsesolinc
Posted: November 15, 2015 at 8:56 AM / IP Logged Link to Post Post Reply Quote howie ll
Have I even got to look that up for you?
Posted: November 15, 2015 at 9:00 AM / IP Logged Link to Post Post Reply Quote howie ll
The part that says "parking light jumpers" and test whether it's POS or NEG on the white wire BEFORE connecting.
dsesolinc
Member - Posts: 8
Posted: November 15, 2015 at 9:02 AM / IP Logged Link to Post Post Reply Quote dsesolinc
no.. I found the jumper
dsesolinc
chev104275
Gold - Posts: 1,419
Posted: November 15, 2015 at 9:08 AM / IP Logged Link to Post Post Reply Quote chev104275
There should be a small black jumper on the side of the module next to the red d2d port. You can select either + or - parking light output using the jumper
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
