rear defrogger 2006 forester
lgammel
Member - Posts: 14
Posted: November 17, 2015 at 5:08 PM / IP Logged Link to Post Post Reply Quote lgammel
Hello and WOW what a great place I stumbled into..
My name is LOnny and I am in p.G. B.C. Can. and drive a 2006 forester (Subaru)
I just recently installed a Avital 4103XL and it works great but I did not hook up the rear defrost until I did a little more research
and that is what led me here .
So far i know it is a neg pulsed system and have programmed the unit for that but now to find the correct wire to connect to ???
rear defrogger 2006 forester -- posted image.
I read schematics a little but I can't figure this out . Please Help its getting cold and snowing here..
SIXER
lgammel
Member - Posts: 14
Posted: November 18, 2015 at 11:05 AM / IP Logged Link to Post Post Reply Quote lgammel
PLease heelp me!
bs1d3
Copper - Posts: 58
Posted: November 19, 2015 at 10:35 AM / IP Logged Link to Post Post Reply Quote bs1d3
Rear defrost is going to be the blue wire, use the blue/white 2nd status/rear defogger output on the avital, program to latch rear defogger
lgammel
Member - Posts: 14
Posted: November 19, 2015 at 1:47 PM / IP Logged Link to Post Post Reply Quote lgammel
Thanks, and are you sure it is latched? I was told it was a neg.
pulse signal.. Where is the easiest place to get to the blue wire ? the center console is a super bitch to get behind.
Sixer
bs1d3
Copper - Posts: 58
Posted: November 19, 2015 at 3:10 PM / IP Logged Link to Post Post Reply Quote bs1d3
I got the info from Directechs, but I was using the US version, my fault.
For Canada it says blue (-) pulsed, at blue plug to left of the steering column.
lgammel
Member - Posts: 14
Posted: November 20, 2015 at 2:33 AM / IP Logged Link to Post Post Reply Quote lgammel
bs1d3;Once again thanks , I hate working outside in negative degree weather so the more info I get the less time I have to spend outside.
I will have a look tomorrow and check back ..
I am glad I found this site , I believe I will get a lot of use and contribute a lot...
Sixer
lgammel
Member - Posts: 14
Posted: November 20, 2015 at 3:53 PM / IP Logged Link to Post Post Reply Quote lgammel
Well I got it to work, bs1d3 you were correct in your first post that I had to program it to latched, everything seems to work good now, I will not know until tomorrow morning when everything is frosted up.
Again I thank you and the12VOLT.COM I will be back for sure...
bs1d3 if you read this what is the diffrence between USA and Can. versions
SIXER
2006 Subaru forester lifted,skid plates, dual batts,winch,inverter etc.
bs1d3
Copper - Posts: 58
Posted: November 21, 2015 at 11:17 AM / IP Logged Link to Post Post Reply Quote bs1d3
I think it's just some legal shenanigans between the two sites as to why they are different, sometimes the US version has better pictures and different locations listed, sometimes the Canada version is better...I use both and just verify the information as I find it.
lgammel
Member - Posts: 14
Posted: November 21, 2015 at 11:50 AM / IP Logged Link to Post Post Reply Quote lgammel
Hey bs1d3 if you are ever in Prince George B.C. let me know and I'll buy you a beer or ten ,Thanks
lgammel
Member - Posts: 14
Posted: November 22, 2015 at 9:26 AM / IP Logged Link to Post Post Reply Quote lgammel
So I thought I had it But if I let my car sit over night it kills the battery and wont start. Any Ideas, everything seemed to work ok until I hooked up the rear defrogger.
Sixer
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
