2009 F350 remote start issue
whatda
Member - Posts: 18
Posted: November 18, 2015 at 4:44 PM / IP Logged Link to Post Post Reply Quote whatda
Hello all, I am installing a Solace S1 with and EVO-All bypass into a 2009 F350. The vehicle starts fine when I hold the key beside the ignition barrel however trying it with the key away it goes through the motions and there is a click but no start then I get 7 flashes of the park light. I should add I have installed the datalink cable as well.
I was told I still needed to hook up the lock/unlock wires but the color and location of the wires do not match my prints from wirecolor.
I should also add that this truck does not have power locks. the bypass module had also been updated and decrypted.
Thanks to all in advance
Posted: November 19, 2015 at 10:42 AM / IP Logged Link to Post Post Reply Quote howie ll
First point bypass isn't working, bad unit or bad programming or wrong wiring.
Second point, if you don't have power locks, why bother with connecting the lock and unlock wires?
whatda
Member - Posts: 18
Posted: November 19, 2015 at 2:16 PM / IP Logged Link to Post Post Reply Quote whatda
Fortin said the box was still looking for that connection. Didn't make sense to me either. Maybe if the wire colors matched what I have from wirecolor I would give it a try but not sure what the correct doortrigger and lock/unlock colors or locations are.
Posted: November 19, 2015 at 2:18 PM / IP Logged Link to Post Post Reply Quote howie ll
Again lock/unlock totally irrelevant, triggers, look to vehicle guide.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
