remote starter wiring, 2010 F-150
lamarsh123
Posted: November 21, 2015 at 4:50 PM / IP Logged Link to Post Post Reply Quote lamarsh123
viper 4105V remote starter in a 2010 F150 wiring diagram
google
the12volt
Administrator - Posts: 3,955
Posted: November 21, 2015 at 4:58 PM / IP Logged Link to Post Post Reply Quote the12volt
lamarsh123
Posted: November 21, 2015 at 6:02 PM / IP Logged Link to Post Post Reply Quote lamarsh123
really could use the wiring diagram that shows where the 9 pin wiring harness from the remote goes specifically in the truck
google
smokeman1
Platinum - Posts: 1,588
Posted: November 22, 2015 at 8:26 AM / IP Logged Link to Post Post Reply Quote smokeman1
Does your F150 have a factory alarm? Smart key or not?
What bypass are you using?
Link to wiring guide:
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
Depending on your wants, you may only need the ground.
lamarsh123
Posted: November 22, 2015 at 10:06 AM / IP Logged Link to Post Post Reply Quote lamarsh123
yes it has a factory alarm, no smart key and I am going to use an idatalink TB
google
lamarsh123
Posted: November 24, 2015 at 4:18 PM / IP Logged Link to Post Post Reply Quote lamarsh123
wondering if anyone has any ideas, titan 143 in a 2010 f150, factory alarm keyless entry. sometimes it works sometimes it doesn't , the valet switch always works and if you unplug the 6 wire power plug,[starter,power, acc , plug ] the truck chirps twice so i know it has power and ground.. sometimes the lock and unlock will work but not the starter button. it also only works if i am in the vehicle [no range] changed the batteries in the remote twice and it won't learn the second remote transmitter which has never been used. Could use some direction.
google
smokeman1
Posted: November 24, 2015 at 4:51 PM / IP Logged Link to Post Post Reply Quote smokeman1
What is a titan 143?
Platinum - Posts: 7,783
Posted: November 24, 2015 at 6:32 PM / IP Logged Link to Post Post Reply Quote kreg357
Here you go, Mr. Smoke :  http://www.titaninnovations.ca/download.php?p=TS143_I.pdf&f=1
For more info on Titan products :  http://www.titaninnovations.ca/old_products.htm  Mostly a Canadian company.
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
