2004 Mazda Tribute Wiring Avital 5303l
aredgoneblue
Posted: November 25, 2015 at 11:33 AM / IP Logged Link to Post Post Reply Quote aredgoneblue
Hey guys,
I am having a hard time with installing a Avital 5303L in a Mazda tribute 2004. Primarily with the Relay Satellite and the unlock lock relays. Also I have an Expresskit PK All Bypass that the wiring is confusing the crap outta me. Any help would be hugely Appreciated!
Thanks!!
chev104275
Gold - Posts: 1,427
Posted: November 25, 2015 at 12:03 PM / IP Logged Link to Post Post Reply Quote chev104275
Start with telling us how you have everything wired up. It will be a lot easier to help if we know what we're working with.
aredgoneblue
Posted: November 25, 2015 at 2:53 PM / IP Logged Link to Post Post Reply Quote aredgoneblue
The problem is I haven't wired anything up yet because I cant really get past the relay satellite..But the satellite is as follows
Heavy Gauge Relay Satellite:
H/1 Purple Starter output to starter (starter side)
H/2 Green Starter input from ignition switch (key side)
H/3 Red (+) 30A High Current 12V input
H/4 Orange Output to accessory Circuit
H/5 Red (+) (30A) High current 12V Input
H/6 Pink Output to Primary ignition Circuit
H/7 RED / white(+) (30A) High Current 12V input
H/8 pink/white Output to second ignition/Accessory Circuit
Relay Satellite 4-pin connector:
1 Blue (-)200mA Status Output
2 Orange (-)200mA Accessory Relay Turn On
3 Purple (-)200mA Starter Relay Turn on
4 Pink (-)200mA Ignition Relay Turn on
Platinum - Posts: 7,783
Posted: November 26, 2015 at 6:44 PM / IP Logged Link to Post Post Reply Quote kreg357
Supplied some answers to your first post in the Vehicle Wiring section.
https://www.the12volt.com/installbay/forum_posts.asp?tid=139774
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
