avital 4103, 2007 ford e-250
justin2010
Member - Posts: 8
Posted: December 12, 2015 at 6:07 PM / IP Logged Link to Post Post Reply Quote justin2010
im trying to install in a 2007 ford e-250,havn,t been able to find a detailed wiring diagram Help, its going to get cold real soon.
Moderator - Posts: 12,488
Posted: December 12, 2015 at 7:45 PM / IP Logged Link to Post Post Reply Quote Velocity Motors
12volts      lt. GREEN/ purple (x2) (common 60A)      +      ignition harness
Starter      WHITE/ pink      +      ignition harness
Second Starter      N/A
Ignition      pink/lt. green      +      ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      gray / YELLOW      +      ignition harness
Second Accessory      BLACK/ lt. green      +      ignition harness
Keysense      BLACK/ pink      -      ignition harness
Power Lock      red to ORANGE / black      5wi      either kick, door harness
Notes: Use the passenger door lock switch when metering the wires, as it is the master switch.
On vehicles with remote keyless entry, use pink / YELLOW (-) for lock and pink/lt. green (-) for unlock in either kick or at the VSM in the passenger kick.
Power Unlock      brown to yellow/red      5wi      either kick, door harness
Lock Motor      pink/black      5wi      VSM in passenger kick
Unlock Motor      RED / orange      5wi      VSM in passenger kick
Parking Lights+      brown      +      headlight switch
Parking Lights-      N/A
Hazards      same as turn signal wires
Turn Signal(L)      lt grn/wht (F), lt grn/org (R)      +      turn signal switch
Turn Signal(R)      wht/lt blu (F), org/lt blu (R)      +      turn signal switch
Reverse Light      BLACK/ pink      +      driver kick, harness to rear
Door Trigger      RED / pink      -      driver kick
Dome Supervision      BLACK/ lt. blue      +      relay to right of steering column
Trunk/Hatch Pin      same as right front door trigger
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      N/A
Factory Alarm Disarm      N/A
Disarm No Unlock      N/A
Tachometer      WHITE/ pink      ac      PCM, top plug, pin 25 (gas) or pin 1 (diesel)
Notes: The PCM is under the hood, next to the brake master cylinder.
Wait to start      see Tech Doc 1091
Brake Wire      dk. green      +      brake pedal switch
Parking Brake      lt. GREEN/ red      -      parking brake switch
Horn Trigger      dk. blue      -      horn switch
chev104275
Gold - Posts: 1,424
Posted: December 12, 2015 at 7:46 PM / IP Logged Link to Post Post Reply Quote chev104275
Readyremote.com and bulldogsecurity.com both have the wiring
justin2010
Member - Posts: 8
Posted: December 13, 2015 at 6:11 AM / IP Logged Link to Post Post Reply Quote justin2010
Thanks, seems like i got the main heavy wires connected correctly,obviously the ground is connected and the aentenna is plugged in . I cant get the programing light to do anything.
Basicaly i can take it from there once i have the barebones wiring done to make this thing start.
Does the nuetral safety switch connection need to be done for this model to work?
chev104275
Gold - Posts: 1,424
Posted: December 13, 2015 at 9:13 AM / IP Logged Link to Post Post Reply Quote chev104275
Neutral safety goes to ground if it's an automatic. If you can't get into programming try pressing the unlock on the remote before getting into programming
justin2010
Member - Posts: 8
Posted: December 19, 2015 at 5:02 AM / IP Logged Link to Post Post Reply Quote justin2010
Is the neutral safety needed for the 4103 to work?
I believe i have everything else correct but i cant get the program light to come on
chev104275
Gold - Posts: 1,424
Posted: December 19, 2015 at 5:16 AM / IP Logged Link to Post Post Reply Quote chev104275
Neutral safety needs to be connected if you want theremote start to work.
justin2010
Member - Posts: 8
Posted: December 19, 2015 at 3:21 PM / IP Logged Link to Post Post Reply Quote justin2010
Thanks , i will try that asap,i have installed other brands in the past and this one seems to be more complicated than the previous installs.
Does, anyone know the only connections needed to get this thing going?
Im not worried about doorlocks yet ,thanks
lectricguy
Copper - Posts: 359
Posted: December 19, 2015 at 4:21 PM / IP Logged Link to Post Post Reply Quote lectricguy
Wait to start      see Tech Doc 1091 --ONLY NEEDED IF DIESEL
Note: horn is optional but provides audible feedback when programming.
Also need to bypass transponder.
Hope this helps.
Lectric Guy
justin2010
Member - Posts: 8
Posted: December 31, 2015 at 4:33 PM / IP Logged Link to Post Post Reply Quote justin2010
Bypass transponder ?
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
