dei 2102t
kulblue
Copper - Posts: 74
Posted: January 07, 2016 at 6:25 PM / IP Logged Link to Post Post Reply Quote kulblue
I had Avital 5303L and DBALL2 on my Accord 09. I tried to install the DEI 2102T but no luck to lock or unlock the Accord. I did is plug-in the Antenna and D2D then pairing the fob.I need to flash the DEI 2102T? Someone can help me? I apperciate it. Thanks
kulblue
Copper - Posts: 74
Posted: January 09, 2016 at 12:54 AM / IP Logged Link to Post Post Reply Quote kulblue
I need to pairing the pke from Avital but I don't know how to do it. Someone can help me? Thanks.
northern
Copper - Posts: 154
Posted: January 09, 2016 at 5:48 PM / IP Logged Link to Post Post Reply Quote northern
What did you find out? I am looking at ordering a few of these, but if people are having problems I might step back
kulblue
Copper - Posts: 74
Posted: January 10, 2016 at 1:24 AM / IP Logged Link to Post Post Reply Quote kulblue
Still can't figure it out how to do the pairing. No luck yet. I hope some one can help.
I tried The Type 1 Diagram and works fine. Just need to pairing the pke system to remote starter module/Avital.
northern
Copper - Posts: 154
Posted: January 11, 2016 at 3:27 PM / IP Logged Link to Post Post Reply Quote northern
Did you try DEI tech support? Although I believe they are the worst in the industry sometimes they are able to lend a hand.
I think im just going to buy a few of them since they only cost $30.
Maybe I'll check around the directed dealer forums for better responses.
smokeman1
Platinum - Posts: 1,588
Posted: January 11, 2016 at 4:28 PM / IP Logged Link to Post Post Reply Quote smokeman1
I don't see anything in the instructions for connecting to a Avital 5303. Are you using a 8210 universal adaptor?
Which type setup are you using?
Instructions on Page 23:
1. Place the remote starter in paring mode.
2.Press and hold the programming button on the PKE(2102t). The LED will flash 3 times to confirm that data is being sent to the remote starter,
3. Release the programing button. The remote starter will confirm the remote learning operation.
kulblue
Copper - Posts: 74
Posted: January 11, 2016 at 4:35 PM / IP Logged Link to Post Post Reply Quote kulblue
Never try yet to contact DEI. Pls! lmk if you get info.
kulblue
Copper - Posts: 74
Posted: January 11, 2016 at 4:49 PM / IP Logged Link to Post Post Reply Quote kulblue
Im using the Type 2a diagram and I bought the 8210 adapter.
How to do the remote starter in pairing mode?
Turn on key position. press and release valet switch then press and hold the valet switch, siren chip once then relaese the valet switch. Means is pairing mode?pls lmk if I did it right. I tried that but no luck. Maybe I did it wrong way. Thanks for reply.
I never hook up any of the 10-pin white connector from 2102t. I thought the D2D will do everything.
smokeman1
Posted: January 11, 2016 at 6:43 PM / IP Logged Link to Post Post Reply Quote smokeman1
Again, don't know if this will work with the 5303.
Maybe you could try changing the RF Protocol of the 2102, listed on page 21 of the instructions, then try pairing the 2102 with the remote starter.
Paring instructions for the 5303 are in the install guide.
kulblue
Copper - Posts: 74
Posted: January 12, 2016 at 2:35 AM / IP Logged Link to Post Post Reply Quote kulblue
I did that too. I program it first then pairing it but still no luck.. I will try on my odyssey I had python 5303p and dball.. The python 5303p same like avital 5303L. But I will give it a try maybe will work...
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
