Lost transmitter for remote starter 4x03
yogi19622002
Member - Posts: 6
Posted: January 25, 2016 at 9:43 AM / IP Logged Link to Post Post Reply Quote yogi19622002
Hello
I purchased a used car but the dealer did not give me the remotes.  I looked under the dash and found a remote starter box DEI 4x03 and a bypass module Audiovox FLCAN.  My question is how can I figure out what is the correct transmitter to use with this system(Viper,Python Avitial …)?  It was installed in 2012-2013.  Can I open the DEI 4x03 and look for a frequency? Should I buy another DEI 4x03 with remotes and just replace the one that is in there.  I found one that matched all of the connectors an Avitial 4113LX but I do not know if I will then need to reflash the FLCAN?
chev104275
Gold - Posts: 1,424
Posted: January 25, 2016 at 10:44 AM / IP Logged Link to Post Post Reply Quote chev104275
I would search for a avital 4103 remotes
smokeman1
Platinum - Posts: 1,588
Posted: January 25, 2016 at 11:05 AM / IP Logged Link to Post Post Reply Quote smokeman1
Can you post a photo of the antenna? Hopefully it is up on the windshield somewhere.
Looks like it might be a Avital 4103.
yogi19622002
Member - Posts: 6
Posted: January 25, 2016 at 3:38 PM / IP Logged Link to Post Post Reply Quote yogi19622002
The antenna is labeled HX Plus. I will try to post a picture.
beegbie
Copper - Posts: 341
Posted: January 25, 2016 at 6:39 PM / IP Logged Link to Post Post Reply Quote beegbie
Sounds like you just need remotes. The only question is if you should buy one button http://www.amazon.com/Remote-Bundle-Automate-1-button-Replacement/dp/B0177D85AE/ref=sr_1_1?s=grocery&ie=UTF8&qid=1453768547&sr=8-1&keywords=automate+one+button+remote
Or 4 button   https://jet.com/product/detail/a5bc35ea86ef478d9ef9ea20d2aaa885?jcmp=pla:ggl:badnj_vehicles_parts_a3:badnj_vehicles_parts_a3:na:na:na:na:na:2&code=PLA15&k_clickid=074c600c-a992-43f5-af42-25402d7bced6&abkId=403-887687&gclid=CO623r6exsoCFYEfHwodRZgOpw
What kind of car is it?
smokeman1
Posted: January 25, 2016 at 6:59 PM / IP Logged Link to Post Post Reply Quote smokeman1
The Avital 4103 install manual lists HX antenna in it.
Doesn't list it as HX Plus though
After some quick research looks like a 474L remote might work with your setup. Can be found on e-bay for 10-15 bucks.
Just my best S.W.A.G. (Sophisticated Wild Ass Guess)
yogi19622002
Member - Posts: 6
Posted: January 26, 2016 at 1:44 PM / IP Logged Link to Post Post Reply Quote yogi19622002
Thanks for the help. I ordered a 4113lx one button remote starter. This way I can try the remotes and if they do not work I have the remote starter box that has the exact same connectors as the 4x03. I posted a photo of the antenna but it did not show up.
yogi19622002
Member - Posts: 6
Posted: January 26, 2016 at 1:56 PM / IP Logged Link to Post Post Reply Quote yogi19622002
I will order the 4 button too. Hopefully I do not need to reflash, I would rather try 2 different remotes first. I ran a status chec on the rs it blinked 4 times. Which indicates transmitter shutdown.
smokeman1
Posted: January 26, 2016 at 3:23 PM / IP Logged Link to Post Post Reply Quote smokeman1
I would pair up the remotes to the remote starter before tinkering with anything else.
Do you see or did you find the valet button? You will need to access that in order to pair the remotes.
yogi19622002
Member - Posts: 6
Posted: January 26, 2016 at 4:33 PM / IP Logged Link to Post Post Reply Quote yogi19622002
Yes I have removed the trim to expose the RS and bypass module. I readup on how to delete the old ones and add the new ones. The RS is working since I was able t get a status out of it using the valet switch. The bypass LED also lit when I pushed the button on the unit.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
