DBALL2 Newer firmware
jameselantra
Copper - Posts: 104
Posted: February 06, 2016 at 10:34 PM / IP Logged Link to Post Post Reply Quote jameselantra
How does one obtain a newer firmware for DBALL2
My firmware changelog goes up to version 2.25 but I can only figure out how to get 1.09
help please. I have xkloader 2 and would like to know how to get the latest firmware. see change log below
Firmware History of 402.HKHT1 v1.09
v2.25Fix Obd Requestv2.24Led diagnostic (follow the guide)v2.21Fix brake status (on then off) when ignition is turn offv2.17update default featurev2.16Fix No startv2.15Fix 1 no start
fix reset when no can is connected
Add 2008- carv2.14-fixed relock after shutdownv2.13- fixed sense trunk issuev2.11- added sense_rke_trunkv2.10- Added auto-relock after shutdown
- Fixed issue when pairing remote after programming devicev2.08change: added controlled doorlock
change: fixed unlock/relock issue at shutdown
change: added alarm sensingv2.07fixed oem fob control issue
beegbie
Copper - Posts: 341
Posted: February 10, 2016 at 6:23 AM / IP Logged Link to Post Post Reply Quote beegbie
Only Alpha testers can access the latest firmwares. They won't publish them until they are proven to work and all of the bugs are worked out. Trust me, you don't want to test these out on your own car.
jameselantra
Copper - Posts: 104
Posted: February 21, 2016 at 4:37 PM / IP Logged Link to Post Post Reply Quote jameselantra
unfortunately the firmware thast is published is buigy as hell on 3 2015 elantras i know.
I guess its time to put garbage in the garbage and go to a different brand.
The elantras Electrical was revised one year after the published firmware and I can grab any elantra with a dball2 in in and replicate 3 very annoying bugs one of which is very bad for the starter motor.
Just finished proving this at an install shop with 3 cars....
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
