Autogas 97 Forester
chris130
Member - Posts: 6
Posted: February 13, 2016 at 10:47 AM / IP Logged Link to Post Post Reply Quote chris130
I have a 97 Subaru Forester T/tb Japanese (ej20 turbo engine)
Iam looking for:
a) RPM (tacho) signal wire
and
b) Ignition (12V) signal wire
Engine compartment wires, ECU pins,
and any wiring diagrams will be very helpful.
thanks
geepherder
Platinum - Posts: 3,668
Posted: February 13, 2016 at 11:07 AM / IP Logged Link to Post Post Reply Quote geepherder
for 1998:
https://www.the12volt.com/installbay/alarmdetail/1970.html
http://readyremote.com/main.asp?action=select&yr=2411&product=Remote%20Start&make=Subaru&model=Forester#
chris130
Member - Posts: 6
Posted: February 13, 2016 at 12:04 PM / IP Logged Link to Post Post Reply Quote chris130
my forester's coil pack has only 3 wires. Any idea which one to use for tacho signal? attached photoAutogas 97 Forester - Last Post -- posted image.
geepherder
Posted: February 14, 2016 at 12:10 AM / IP Logged Link to Post Post Reply Quote geepherder
You'll need to probe and see. Set your multimeter do AC voltage, black lead to ground, red lead to suspect wire. Start the engine. Your voltage will vary with engine speed.
chris130
Member - Posts: 6
Posted: February 14, 2016 at 5:37 AM / IP Logged Link to Post Post Reply Quote chris130
Measured with multimeter
1) RED / green wire - It seems that we found rpm signal
0.5 VAC to 2.0 VAC (idle - accelaration).
Is it an acceptable range or it doesnt matter?
2) light blue wire
Gives 12VDC when the switch turn to ignition position.
3) yellow/red wire should be the ground
geepherder
Posted: February 14, 2016 at 9:01 PM / IP Logged Link to Post Post Reply Quote geepherder
That'll work. Hook it up and reward yourself with a beverage.
chris130
Member - Posts: 6
Posted: February 20, 2016 at 2:08 PM / IP Logged Link to Post Post Reply Quote chris130
Hello
thank you so much for your help
I have another question in case you know.
Im trying to connect GAS ECU wires (optional) to OBD/CAN (6 & 14 pin).
Are there any different kinds of OBD II ? i dont have any wires on 6 & 14 pin of the OBD plug.
thanks
geepherder
Posted: February 21, 2016 at 7:42 AM / IP Logged Link to Post Post Reply Quote geepherder
Yes there are different protocols for OBD II, but your vehicle predates the CAN bus systems. I wouldn't your factory pinout though.
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
