DBALL 2 Brake shutdown in D2D
cneubert42
Member - Posts: 46
Posted: March 03, 2016 at 1:09 PM / IP Logged Link to Post Post Reply Quote cneubert42
So I installed a 4105V with a DBALL 2 in an 08 Tacoma and most of the time the system worked fine, however on occasion the system would shut down early (sometimes in the first few minutes without restarting) Diagnostics told me the shutdown was because of the foot brake being pressed but it was not. I metered the brake wire and it shut down again and no voltage displayed on my meter making me think maybe the unit is bad (doubt it but what else could it be) Today I swapped the unit and on the first start it shut down again for brake input. then I realize that the DBALL2 has the capabilities of monitoring foot brake in some vehicles and even though this isn't one of them maybe that is where my problem is (I did wire it in D2D) I rewired it in W2W mode and tested the start about 25 times with no issue (here's to hoping it is fixed) so my question is has anyone ever experienced this? I know alot of you don't like the D2D method, is this the type of issues that cause you guys not to like it? what other issues have you guys experienced with D2D?
beegbie
Copper - Posts: 341
Posted: March 03, 2016 at 5:18 PM / IP Logged Link to Post Post Reply Quote beegbie
Very strange but not impossible. I love the db-all2 for many applications in newer cars. However, on older cars I don't trust them. When firmwares come out there are many updates for different issues and applications. After a little while, the firmwares become reliable. You have two factors against you. One is that the db-all2 didn't exist in 2008 and secondly it's not the most efficient choice for your model (a transponder only bypass would do the same for cheaper). This means there are probably not many people installing this combination of products in a 2008 Tacoma so there may be bugs that aren't reported/fixed.
beegbie
Copper - Posts: 341
Posted: March 03, 2016 at 5:25 PM / IP Logged Link to Post Post Reply Quote beegbie
Other dbi issues? Where should I start. Back when it first came out, it was useless. Most of the time the gwr would come on too late (after the ignition turned on) and immobilizer bypass would fail. Over the years it's gotten much better but there are still issues. Just google "directed tb-118" and read the first result. This one caused hundreds of cars to come back for us and they are still coming back to this day.
tacoma1588
Member - Posts: 9
Posted: March 03, 2016 at 6:50 PM / IP Logged Link to Post Post Reply Quote tacoma1588
My 4105v seems to blame the brake shutdown wire alot as well. Make sure your brake wire is really secured.
dasbogie
Silver - Posts: 514
Posted: March 03, 2016 at 8:11 PM / IP Logged Link to Post Post Reply Quote dasbogie
I have seen this behavior with dball2 on some Toyotas/Chryslers. I usually end up just turning off d2d brake on dbal2 and hardwiring to vehicle. Especially in a suspect Chryslers, the WHITE/ tan vehicle brake wire isn't far from where I secure the brainbox anyway. Side note: I have also seen this behavior with idatalinks al-ca/blade modules. Something else to consider is tach. If you haven't hard wired tach, I would recommend it. That could also be your situation.
Advanced
navyrunner
Posted: April 14, 2016 at 1:39 AM / IP Logged Link to Post Post Reply Quote navyrunner
First post here but these forums have been an awesome source of valuable knowledge for me.
Cneubert42-
I know it's been over a month and you probably have it figured out by now but I had the same problem in my '05 4Runner. I installed a Viper 5706v and the Dball2 bypass module. Everything worked fine except that when I would use the remote start, the truck would run for approx 30 seconds and then shutdown. The shutdown troubleshooting diagnosis said it the brake pedal shut it down (5 flashes of the parking lights) even though I hadn't touched it. I searched the Internet for "brake wire shutdown remote start" etc... but came up with nothing. I called a few install shops and the general concensus was that it was the tach (I have it hardwired) causing the shutdown even though the shutdown diagnosis said it was the brake. The odd thing was that if I tried the remote start again immediately after it shutdown the first time, it would stay running for the whole 12 minutes without issue. Anyway long story short it turned out to be the Dball2. I have it connected D2D and when you flash it on the computer, it defaults to having the bypass module filter all of the shutdowns. I flashed the Dball2 again and unchecked those 6 or 7 shutdown features and it works perfectly now. Again you're probably good to go now but I hope this helps someone else! Thanks to everyone who shares their lessons learned and knowledge and sorry for the long post!
tacoma1588
Member - Posts: 9
Posted: April 14, 2016 at 7:10 AM / IP Logged Link to Post Post Reply Quote tacoma1588
That's awesome to know. I switched to tach sensing and it worked fine a couple of times, and then I started having issues where it would keep cranking and not turn over. Virtual tach and voltage stall the truck while cranking, sometimes it works. I then switched the sensing to off, so it doesn't detect anything. Now it cranks over. Out of prolly 30 uses it didn't crank over 2 times. I chalk it up to the programming of the dball not communicating correctly to my trucks immobilizer system that's causing my issues between virtual tach, tach, and voltage sensing.
cneubert42
Member - Posts: 46
Posted: April 14, 2016 at 10:34 AM / IP Logged Link to Post Post Reply Quote cneubert42
Just to update it was the DBall, I switched from d2d to w2w and all is good now. Thanks everyone!
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
