2014 F-150 remote turn on lead?
jas51384
Member - Posts: 32
Posted: March 08, 2016 at 2:20 AM / IP Logged Link to Post Post Reply Quote jas51384
Hi all
I'm adding an aftermarket amp to my factory 4.2" sync radio. The amp I have has the speaker level inputs but they aren't auto sensing to switch the amp on and off. I'm trying to find the best way to wire the remote turn on lead. I know they made a kicker add-on sub kit that wired in somehow. Is there a factory lead or do I need to rig it to a different switch 12v source? Thanks in advance.
rs specialist
Copper - Posts: 175
Posted: March 08, 2016 at 11:39 AM / IP Logged Link to Post Post Reply Quote rs specialist
You can use the accessory circuit to turn the amp on.
jas51384
Member - Posts: 32
Posted: March 08, 2016 at 3:23 PM / IP Logged Link to Post Post Reply Quote jas51384
Won't this turn the amp on and off with the key? Is there a way to wire it to the radio? Maybe an antenna power wire? I just don't have a wiring diagram to find the colors.
jas51384
Member - Posts: 32
Posted: March 18, 2016 at 8:32 PM / IP Logged Link to Post Post Reply Quote jas51384
Pin 18 in the 26 pin connector on the back of the radio. 4.2 LCD sync system
pegleg1960
Member - Posts: 20
Posted: March 21, 2016 at 8:42 AM / IP Logged Link to Post Post Reply Quote pegleg1960
I have three amps and turn them on with toggle switches because I don't want to power up 9600 watts at one time. I believe the easiest way is to either run a wire from your battery or pick up a 12 volt wire in the cab of your truck. The easiest would be to use a wire from the cigarette lighter and toggle it.
Pegleg Charlie
Builder-Charlie Cannon Subwoofer Enclosures and general troublemaker at
LMMFAO Corp.(LOL)
series vii
Member - Posts: 27
Posted: March 29, 2016 at 10:12 AM / IP Logged Link to Post Post Reply Quote series vii
In the fuse box, under the hood, is a fuse and relay for the trailer battery charging circuit which is key switched. It is a 10 or 12 Awg Orange wire. It runs along the drivers frame rail and ends in a multi connector under the bed near the rear bumper.
'14 F-150 Platinum.
Not giving up my class A/B yet...
jas51384
Member - Posts: 32
Posted: June 19, 2017 at 8:07 PM / IP Logged Link to Post Post Reply Quote jas51384
Sorry to bump my old post but I wanted to thank everyone for their help. I haven't set up anything permanent yet. For now I'm using a High input to low input converter that has an amp turn on lead. It's not ideal but will do for now.
ocautostyle
Posted: September 01, 2017 at 2:04 PM / IP Logged Link to Post Post Reply Quote ocautostyle
I just ran into this on a install its the amps ur using not the loc or remote wires. I tried a kicker amp no good, arc no good, but i used an
Avionixx (axa 740) and a (axa 2200) and it works good.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
