3 way switch, e-fan wiring
dew1989
Member - Posts: 12
Posted: March 29, 2016 at 2:47 PM / IP Logged Link to Post Post Reply Quote dew1989
Hello,
I'm trying to figure out how to wire this up with no avail. What I'm trying to do is have a 3 way switch set up so I can run my 100% manual e-fan setup (one fan - off - two fans). The challenge I'm having is when the switch is on the 'two fan' setting, both fans need to turn on, but how do I wire this up so on the 'one fan' setting both fans don't turn on as well. Each fan is has independent wiring.
Thanks in advance
Ween
Platinum - Posts: 1,366
Posted: March 29, 2016 at 8:02 PM / IP Logged Link to Post Post Reply Quote Ween
So you are using a SPDT center off switch which triggers your fan relays? A diode connected across the outer terminals will give you a one/two fan operation. A 1N4000 series diode will work fine, assuming you are using bosch/tyco style relays.
geepherder
Platinum - Posts: 3,668
Posted: March 29, 2016 at 8:57 PM / IP Logged Link to Post Post Reply Quote geepherder
https://www.the12volt.com/installbay/forum_posts.asp?tid=140753
dew1989
Member - Posts: 12
Posted: April 01, 2016 at 3:26 PM / IP Logged Link to Post Post Reply Quote dew1989
Thanks guys, this should do the trick!
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
