2014 Honda CR-V with Viper 4806V and DBALL
beedix
Member - Posts: 24
Posted: April 28, 2016 at 1:16 PM / IP Logged Link to Post Post Reply Quote beedix
Hoping I could get a little help with a couple of connections. Planning to use D2D for this install and I'm using the DBALL installation diagram.
1) Diagram shows (-)Parking Lights on the remote start. I found a 1 page install guide for the 4806 and I don't see this connection identified on the remote start end of things.
2) Diagram shows (+)Accessory 2 on the remote start. (+)Accessory is the Orange wire in the 8-pin connector I believe. I did not see more than this one positive accessory in the install guide. Should I connect it to both 1 and 2 in the ignition?
Platinum - Posts: 7,781
Posted: April 28, 2016 at 2:41 PM / IP Logged Link to Post Post Reply Quote kreg357
The Viper has a thick Pink/White IGN2 output that is programmable to Accessory2.  See Menu 3, Item 8, Option 2.  This can be used to properly power the CR-V's ACC2 circuit.
The Viper H/5 WHITE PIN 30 of LIGHT FLASH RELAY is the Parking Light output wire.  There is a Jumper/Fuse inside the Viper to select to polarity of the output.
beedix
Member - Posts: 24
Posted: April 28, 2016 at 3:40 PM / IP Logged Link to Post Post Reply Quote beedix
Thanks, that's very helpful.
Do you happen to know if the polarity selection jumper defaulted to negative?
Posted: April 28, 2016 at 10:13 PM / IP Logged Link to Post Post Reply Quote kreg357
No, usually it's set to (+) but sometimes falls off during shipping...   2014 Honda CR-V with Viper 4806V and DBALL -- posted image.
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
