2001 toyota corolla viper 5305v issue
wayko
Posted: April 30, 2016 at 12:23 AM / IP Logged Link to Post Post Reply Quote wayko
Hi all I am installing a 5305v in a 2001 toyota corolla. The alarm is working I can arm and disarm and get signal when the alarm is triggered, but when I try to run the remote start the system will buzz the led on the control will flash like 13 times then the parking light would flash this would happen 3 times then finally the system would stop trying to start the car.
I tried grounding the WHITE/ blue wire and I would hear the system beep but nothing will happen. I connected the tach wire to the white wire at my ignition coil.
I'm at a loss at this point
Any help would be appreciated
Platinum - Posts: 7,783
Posted: April 30, 2016 at 5:11 AM / IP Logged Link to Post Post Reply Quote kreg357
Perhaps you could list your Viper to vehicle connections?  That will give us a better idea of what is going on.
wayko
Posted: April 30, 2016 at 7:48 AM / IP Logged Link to Post Post Reply Quote wayko
I will get you that info today
wayko
Posted: May 01, 2016 at 9:41 PM / IP Logged Link to Post Post Reply Quote wayko
Main 5 pin Harness
Black - (-)chassis ground connected
Brown - (+)siren output connected
Red - (+)fused 12v DC constant input connected
Orange - (-) 500mA GWA (ground when armed) output not used
White - (+)/(-) selectable parking light output fused connected
24 pin
Pink/white connected ignition 2
Blue/white NC
RED / white NC
BLACK / YELLOW NC
Dark blue NC
WHITE/ black NC
WHITE/ violet NC
ORANGE / black NC
Gray connected hood pin
Blue NC
WHITE/ blue ? NC (-) remote start activation input
Violet/white - connected ignition coil white
BLACK/ white - connected parking brake
GREEN/ black NC
Green connected door trigger
BROWN / black NC
Pink connected ignition 1
Violet NC
Violet/black NC
Brown connected brake shut down
Violet / YELLOW connected to pin 7 violet of 10 pin harness
Gray/black NC
GREEN / WHITE NC
   2001 toyota corolla viper 5305v issue - Last Post -- posted image.
Posted: May 02, 2016 at 4:16 AM / IP Logged Link to Post Post Reply Quote kreg357
You didn't list any connections for the most important harness.  The 10 Pin heavy gauge wire harness must be connected
for the car to remote start.
Remote Start, White 10-pin heavy gauge connector
1 No Connection
2 RED / BLACK (+) FUSED 12V ACCESSORY/STARTER INPUT     White (50A) +  @ ignition switch, white 8 pin plug, pin 2
3 PINK/BLACK* (+) IGNITION 2/ACCESSORY Pin  # 87A    Not Used
4 PINK/WHITE (+) IGNITION 2 / ACCESSORY OUTPUT     BLACK / YELLOW +  @ ignition switch, white 8 pin plug, pin 4
5 RED (+) FUSED 12V IGNITION 1 INPUT White (50A) +  @ ignition switch, white 8 pin plug, pin 2
6 GREEN (+) STARTER INPUT (KEY SIDE) cut wire Red +  @ ignition switch, white 8 pin plug, pin 8
7 VIOLET (+) STARTER OUTPUT (CAR SIDE)     cut wire    Red +  @ ignition switch, white 8 pin plug, pin 8
8 ORANGE (+) ACCESSORY OUTPUT       Blue/Red +  @ ignition switch, white 8 pin plug, pin 3
9 RED / WHITE (+) FUSED 12V IGNITION 2 / FLEX RELAY White (50A) +  @ ignition switch, white 8 pin plug, pin 2
10 PINK (+) IGNITION 1 INPUT/OUTPUT    BLACK/ White +  @ ignition switch, white 8 pin plug, pin 6
Corrections for the 24 Pin harness :
1 PNK/WHITE (-) 200mA IGNITION 2/ACCESSORY OUTPUT        Not Used
2 BLUE/WHITE (-) 200mA 2ND STATUS /REAR DEFOGGER OUTPUT     Not Used
3 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT        Not Used
4 BLACK / YELLOW (-) 200mA DOME LIGHT OUTPUT        Not Used
5 DARK BLUE (-) 200mA STATUS OUTPUT           Not Used
6 WHITE/ BLACK (-) 200mA AUX 5 OUTPUT           Not Used
7 WHITE/ VIOLET (-) 200mA 2nd UNLOCK OUTPUT Not Used
8 ORANGE / BLACK (-) 200mA AUX 6 OUTPUT        Not Used
9 GRAY (-) HOOD PIN INPUT         kit supplied hood pin
10 BLUE (-) TRUNK PIN/INSTANT TRIGGER INPUT           RED / white (-)  luggage compartment light, gray 2 pin plug, pin 2
11 WHITE/ BLUE ** (-) REMOTE START ACTIVATION INPUT          Not Used
12 VIOLET/WHITE TACHOMETER INPUT           RED / blue, YELLOW /GREEN, gray, or white  ac  any ignition coil, black 4 pin plug, pin 3
13 BLACK/ WHITE* (-) PARKING BRAKE INPUT/EMERGENCY INPUT       Chassis ground if auto trans
14 GREEN/ BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT Not Used
15 GREEN (-) DOOR INPUT           RED / white (-)  behind dash fuse box, white 3 pin plug, pin 1
16 BROWN / BLACK (-) 200mA HORN HONK OUTPUT         Not Used
17 PINK (-) 200mA IGNITION 1 OUTPUT    Not Used
18 VIOLET (+) DOOR INPUT           Not Used
19 VIOLET/BLACK (-) 200mA AUX 4 OUTPUT         Not Used
20 BROWN (+) BRAKE SHUTDOWN INPUT GREEN / WHITE (+)  @ brake switch, blue 5 pin plug, pin 1
21 VIOLET / YELLOW (-) 200mA STARTER OUTPUT           Not Used
22 GRAY/BLACK (-) DIESEL WTS (WAIT-TO-START) INPUT          Not Used
23 ORANGE (-) 200mA ACCESSORY OUTPUT      Not Used
24 GREEN / WHITE (-) 200mA FACTORY ALARM ARM OUTPUT     Not Used
Immediately disconnect Pin 17 and Pin 21 connections you listed.  Hopefully these did not fry your Viper.
wayko
Posted: May 17, 2016 at 6:30 PM / IP Logged Link to Post Post Reply Quote wayko
I have one more question when I unlock the door with the remote the door lock opens then closes. I will have to try opening it again to pulse once. Is there a setting to change it?
Posted: May 19, 2016 at 7:08 AM / IP Logged Link to Post Post Reply Quote kreg357
On your 5305, check Menu 2 Item 7 for Unlock Pulse. Option 1 is default for a single unlock output. Option 2
is the setting for a double unlock output.
Posted: May 19, 2016 at 11:15 AM / IP Logged Link to Post Post Reply Quote howie ll
Oh, hello Kreg, just about to comment when I saw your last line:-"Immediately disconnect Pin 17 and Pin 21 connections you listed. Hopefully these did not fry your Viper."
Unfortunately pin 21 connection might have done.
A case of either not reading nor understanding the instructions.
Posted: May 19, 2016 at 9:49 PM / IP Logged Link to Post Post Reply Quote kreg357
Hi, Howard. The unlock issue is a bit strange. Don't know if that's a programming issue.
How about those Hotspurs! #3    2001 toyota corolla viper 5305v issue - Last Post -- posted image.
Posted: May 20, 2016 at 1:40 AM / IP Logged Link to Post Post Reply Quote howie ll
We fell apart against the Scum (Chelsea)then had our biggest defeat in 4 years against a team going down when all we had to do was draw to come second still a good season, 2 good players for next ear and we might be there.
I'll leave you and our OP with two thoughts, KEYSENSE required and maybe a fauty micro switch or motor out of position in one of the front doors.
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
