Central locking relay wiring
georgehockin
Posted: May 20, 2016 at 3:24 PM / IP Logged Link to Post Post Reply Quote georgehockin
I need to add a relay to my central locking and I'm after a diagram
Locking -
Pin 1 - positive
Pin 2 - neg
Unlocking -
Pin 1 - neg
Pin 2 - positive
Any help would be much appreciated !
the12volt
Administrator - Posts: 3,955
Posted: May 20, 2016 at 4:41 PM / IP Logged Link to Post Post Reply Quote the12volt
I could assume each lead is resting at ground, though it's possible they both rest open, or even at positive, and it's never safe to assume, so what year, make, and model vehicle do you have?
Central locking relay wiring - Last Post -- posted image. the12volt • Support the12volt.com
georgehockin
Posted: May 20, 2016 at 4:43 PM / IP Logged Link to Post Post Reply Quote georgehockin
2006 Audi A3 taking the feed from the filler door lock will check what they rest at
Posted: May 20, 2016 at 5:20 PM / IP Logged Link to Post Post Reply Quote howie ll
Should rest at open circuit, ground to lock/unlock, lock pin 2, unlock pin 1. Use a 1N4004 diode in line, band towards your unit.
Alternative, this maybe a 1 wire multiplex operation, not sure myself because I always used a DB-all 2 if you're going your route use a DEI 451 comes with resistors and should plug into your alarm assuming you're using a DEI product.
Posted: May 20, 2016 at 5:25 PM / IP Logged Link to Post Post Reply Quote howie ll
Forget the filler cap BTW lock control on that vehicle, UK spec is at the near (left) hand hatch area just inside the rear light fitting, much easier to use3 a DB-ALL2, it will save you hours of wiring and probing on that vehicle.
Posted: May 20, 2016 at 5:29 PM / IP Logged Link to Post Post Reply Quote howie ll
DB-ALL 2 functions:-
After Market Alarm Control using OE Remote
•Brake Status (Foot Brake)
•Door Entry Monitoring
•Door Lock / Unlock Control
•Factory Security Control
•Hood / Trunk Pin Entry Monitoring
•Power Window / Seat / Sunroof Control
•Tach / RPM Output
•Tach / RPM Output
•Trunk / Hatch Release
Detailed Function List
W2W
AV-Turn Signal ON/OFF Control
CC-Comfort Closure windows
DL-Arm Factory Security
DL-Disarm Factory Security
DL-Door Lock Control
DL-Door Unlock
DL-Trunk / Hatch Release
RS-Tach / RPM Output
SS-Entry Monitoring ALL Door Pins
SS-Entry Monitoring Trunk/Hatch Pin
D2D
DL-Door Unlock
FOB-Control of aftermarket alarm with OEM remote
SS-Entry Monitoring Driver Door Pin
SS-Entry Monitoring Hood Pin
ST-Brake Status (foot brake)
ST-Ignition Status
georgehockin
Posted: May 21, 2016 at 5:30 PM / IP Logged Link to Post Post Reply Quote georgehockin
The loom has been retro fitted to another vehicle so I have to use these and both wires rest at a very weak earth
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
