97 acura cl radio install
cjf102379
Posted: June 12, 2016 at 12:56 PM / IP Logged Link to Post Post Reply Quote cjf102379
Wireharness has been cut off my car I followed the guide that posted on here to
Wire it however, i cant find the blue and white wire for the constant or the yellow and red for the switched. Is it possible itcouldbe a different color?
Cjf102379
Posted: June 12, 2016 at 1:40 PM / IP Logged Link to Post Post Reply Quote howie ll
Try WHITE/ blue and RED / yellow or pick them up at the ignition switch loom.
Platinum - Posts: 13,667
Posted: June 12, 2016 at 5:04 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Battery WHITE/ yellow
Switched WHITE/ red
Do you have a multimeter? Find the speaker wires and you will have only a few wires left. Check both of the radio fuses before using the meter to find constant and switched wires.
Posted: June 12, 2016 at 5:35 PM / IP Logged Link to Post Post Reply Quote howie ll
8 x speaker wires.
1 X 12V+ constant.
1 X 12V+ ACC.
1 X 12V+ ILLUMINATION.
1 X Antenna switched by head unit.*
1 X GROUND.
*To verify antenna, use a test light with an incandescent bulb, feed 12V+ to one side, other to suspect wire. If correct it will raise the antenna and DOI NO HARM if connected to a wrong wire.
N.B. If there's another wire that might be speed pulse for NAV (optional) though I believe this vehicle is too early.
PS to ascertain speaker wires find the other wires first; then with your 12 volt constant and ground wires you can find your speaker wires. You've got to work out phasing then note look under the rear shelf at the back of the speakers, that will give you left and right rear or 4 of the 8. The terminal on the right side is the + terminal.
cjf102379
Posted: June 13, 2016 at 2:58 PM / IP Logged Link to Post Post Reply Quote cjf102379
I have everything figured out but the power antenna. What color do i connect it on the factory wire
Cjf102379
Posted: June 13, 2016 at 8:13 PM / IP Logged Link to Post Post Reply Quote i am an idiot
RED / Black is illumination. Remove RED / black from the equation and how many wires are not used? What colors are they?
Posted: June 14, 2016 at 1:04 AM / IP Logged Link to Post Post Reply Quote howie ll
I just told you how to test for power antenna wire.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
