Switched Dist. Block Using Relay
baff2004
Member - Posts: 7
Posted: June 14, 2016 at 2:41 PM / IP Logged Link to Post Post Reply Quote baff2004
Hi everyone!
I'll get right to it. I'm in the process of adding accessories to a side-by-side UTV. I have a small busbar wired under the hood with +/-/acc, functioning. I would like to clean things up and have a power dist. block with all the fuses for my new accessories in line.
Question is: Can I take a 30/40A relay from one of those Amazon wiring harnesses wired from the busbar's acc. and + to provide switched power to the dist. block? Will I need high gauge wire or a bigger relay? The busbar would only be inches away from the dist. block. I would be powering LED light bars, stereo, overhead console lights, LED flag whips, ect... I have a winch currently wired directly to the busbar with a stock heavy gauge wire harness.
tonanzith
Gold - Posts: 593
Posted: June 14, 2016 at 9:56 PM / IP Logged Link to Post Post Reply Quote tonanzith
honestly i'd use more of a solenoid like this as an example:
solenoid 100 amp
or copy and paste, for some reason the embedded url wasn't working,
http://www.delcity.net/store/Grounded-Continuous-Solenoids-!-SPST/p_743393.h_817797.t_1.r_IF1003?mkwid=stOATPoH0&crid=38094426869&mp_kw=&mp_mt=&gclid=CJbr_vWDqc0CFUdlfgod6mgBIQ
this is a 100 amp continuous solenoid but there are larger if needed.
Gary Sather
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
