Alternative wig wag circuit?
scottishguy
Posted: June 14, 2016 at 5:54 PM / IP Logged Link to Post Post Reply Quote scottishguy
Here's a youtube video of an alternative circuit using only one relay contrary to the methods shown on this site for example here > https://www.the12volt.com/relays/relaydiagram57.html
This video details a single relay system > https://youtu.be/XVa0-R86Js0?t=3m39s
Has anyone tried this?
tonanzith
Gold - Posts: 593
Posted: June 14, 2016 at 10:14 PM / IP Logged Link to Post Post Reply Quote tonanzith
yep, that works.
Gary Sather
scottishguy
Posted: June 15, 2016 at 3:52 PM / IP Logged Link to Post Post Reply Quote scottishguy
I had no sucess getting any version of a single relay/flasher to sucessfully wig wag. After much head scratching and a little cursing I went back to first princples & learned how relays work and then realised my problem. I had a S2 type relay, that is there is no 87a (normally closed) terminal Alternative wig wag circuit? -- posted image. Alternative wig wag circuit? -- posted image.
My question now is, could I use these 8 pin (yes 8 pin I'm getting confident now Alternative wig wag circuit? -- posted image. ) to control low power LEDs in an automotive setting. These relays have a small physical size and are very cheap.
http://www.ebay.co.uk/itm/5pcs-High-Quality-8-Pins-RELAY-12V-DC-Coil-Power-Relay-PCB-HK19F-DC12V-SHG-/272256820055?hash=item3f63c56357:g:avkAAOSwR5dXSUrl
scottishguy
Posted: June 19, 2016 at 4:30 PM / IP Logged Link to Post Post Reply Quote scottishguy
Starting to get my head round this now :)
I made the world's first 100 watt LED wig wag flashlight which includes a over temperature alarm all controlled by a single 12v car signal flasher.
https://youtu.be/4Za4uYLgDYU
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
