2009 Hyundai Sonata Stereo Wiring
ialex27
Posted: July 12, 2016 at 6:22 PM / IP Logged
I'm looking to install a subwoofer into my stock radio on my 2009 Hyundai Sonata, would anybody happen to have a wiring map for the back of the radio by chance? Or know where I can find one?
tonanzith
Gold - Posts: 593
Posted: July 12, 2016 at 8:19 PM / IP Logged
2009 Hyundai Sonata     DirectWire Vehicle Information
Audio
Item     Wire Color     Polarity     Wire Location
Radio 12V     gray     +     radio, gray 8 pin plug, pin 4
Radio Ground     black     -     radio, gray 8 pin plug, pin 8
Radio Ignition     ORANGE / black     +     radio, gray 8 pin plug, pin 6
Radio Illumination     blue (parking lights), WHITE/ black (dimmer)     +,-     radio, gray 8 pin plug, pins 2 and 7
Factory Amp Turn-on     pink/black     +     radio, blue 8 pin plug, pin 6 or 8
Power Antenna     GREEN/ black     +     radio, gray 8 pin plug, pin 3
Left Front Speaker (+/-)     blue - orange     +,-     radio, brown 8 pin plug, pins 3 and 7
If equipped, the amplifier is in the right side of the trunk. On vehicles with amplifier, the speaker wires are blue - orange at the amplifier, 26 pin plug, pins 2 and 15 (audio amp), or 14 pin plug, pins 6 and 14 (JBL amp). The tweeter wires are gray/black - ORANGE / black at the amplifier, 12 pin plug, pins 6 and 12 (audio amp), or 20 pin plug, pins 9 and 20 (JBL amp).
Right Front Speaker (+/-)     blue/orange - yellow     +,-     radio, brown 8 pin plug, pins 2 and 6
If equipped, the amplifier is in the right side of the trunk. On vehicles with amplifier, the speaker wires are blue/orange - GREEN/ black at the amplifier, 26 pin plug, pins 1 and 14 (audio amp), or 14 pin plug, pins 5 and 13 (JBL amp). The tweeter wires are WHITE/ orange - RED / orange at the amplifier, 12 pin plug, pins 5 and 11 (audio amp), or 20 pin plug, pins 8 and 19 (JBL amp).
Left Rear Speaker (+/-)     green - pink     +,-     radio, brown 8 pin plug, pins 4 and 8
If equipped, the amplifier is in the right side of the trunk. On vehicles with amplifier, the speaker wires are green - pink at the amplifier, 12 pin plug, pins 4 and 10 (audio amp), or 14 pin plug, pins 4 and 12 (JBL amp).
Right Rear Speaker (+/-)     white - brown     +,-     radio, brown 8 pin plug, pins 1 and 5
If equipped, the amplifier is in the right side of the trunk. On vehicles with amplifier, the speaker wires are white - brown at the amplifier, 12 pin plug, pins 3 and 9 (audio amp), or 14 pin plug, pins 3 and 9 (JBL amp).
Center Channel (+/-)     N/A
Subwoofer (+/-)     GREEN/ org - pink/blk (1); yellow/org - red (2)     +,-     amplifier, 12 pin plug, pins 2 and 8; 1 and 7
If equipped, the amplifier is in the right side of the trunk. On vehicles with JBL amp, they are in the 14 pin plug, pins 1 and 7; 2 and 8.
Aux. Audio Input Left (+/-)     red - white     +,-     radio, green 6 pin plug, pins 2 and 3
Aux. Audio Input Right (+/-)     black - white     +,-     radio, green 6 pin plug, pins 1 and 3
RSE Video (+/-)     green - WHITE/ black (aux video)     +,-     radio, blue 8 pin plug, pins 6 and 1
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     N/A
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Gary Sather
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
