Data or RF bypass for 08 GMC Sierra?
timmerk
Member - Posts: 39
Posted: August 02, 2016 at 9:45 PM / IP Logged Link to Post Post Reply Quote timmerk
Anyone have recommendations on doing a data or RF bypass for an 08 GMC Sierra? I will probably be using a Fortin EVO-ALL or DEI DBALL2, and a T-harness. Fortin does't mention power consumption, but DEI recommends the RF route because of power consumption. Is the data route more reliable? Is the bypass just as fast as the RF method?
Thanks!
lurch228
Silver - Posts: 1,338
Posted: August 03, 2016 at 4:45 AM / IP Logged Link to Post Post Reply Quote lurch228
The RF method with the DBALL2 and the RFLCHGM is basically adding (programming)a transponder key and emitting the transponder id to the key cylinder through the loop when remote start is activated. In data mode the DBALL2 needs to stay on to maintain the connection to the vehicle. All other data functions remain unchanged when using the RF mode.
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
