2004 dodge 1500 factory remote start?
bogucki
Copper - Posts: 91
Posted: August 24, 2016 at 10:38 AM / IP Logged Link to Post Post Reply Quote bogucki
hey guys i have a 2004 dodge ram 1500 with the oem dodge remote starter installed but the range is so poor i want to install the 1mile viper 2way remote starter in the truck, i have installed many remote starters but never installed one with a factory remote starter all ready installed, it uses a 2nd one button fob for the remote start, my question is do i have to disable the dodge remote starter or just install the viper as normal and ignore the dodge one ?
boguckialex
rs specialist
Copper - Posts: 175
Posted: August 24, 2016 at 12:58 PM / IP Logged Link to Post Post Reply Quote rs specialist
sounds like you have an add-on remote from the dealer. I would suggest removing the "OEM" system and installing your aftermarket one.
bogucki
Copper - Posts: 91
Posted: August 29, 2016 at 12:48 AM / IP Logged Link to Post Post Reply Quote bogucki
ok so i have discovered that dodge uses the code alarm goh-pcmini remote starter as there oem remote starter , i was wondering if any one has any info on this remote starter and where its located and how to remove it so i can install my viper system?
boguckialex
smokeman1
Platinum - Posts: 1,588
Posted: August 29, 2016 at 6:50 AM / IP Logged Link to Post Post Reply Quote smokeman1
Don't know if this link will help or not. Might be able to used it to identify parts and components:
https://fccid.io/document.php?id=583631
If there is an antenna on the windshield or a hood pin, you should be able to follow those wires back to the remote starter.
bogucki
Copper - Posts: 91
Posted: August 29, 2016 at 12:03 PM / IP Logged Link to Post Post Reply Quote bogucki
thank you smokeman1 that install guide is very helpful and good idea following the antenna cable
boguckialex
bogucki
Copper - Posts: 91
Posted: August 31, 2016 at 4:15 PM / IP Logged Link to Post Post Reply Quote bogucki
i removed the old remote starter it was very easy to remove, installed the viper system had no issues but omg 4 acc wires and two ign wires to power up kinda a pain in the ass i must say
boguckialex
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
