2016 Toyota Tacoma Smart Key Alarm/RS/Stereo Wiring
Home /
the12volt's Install Bay /
Vehicle Wiring Information & File Requests / 2016 Toyota Tacoma Smart Key Alarm/RS/Stereo Wiring ( Topic Closed)
Welcome Guest :)
Posted: September 11, 2016 at 9:54 PM / IP Logged
2016 Toyota Tacoma (Smart Key) - Wire Sheet
Item Wire Color Polarity Wire Location Note
12 Volts black (50A) + dash fuse box, white 1 pin plug (1L), pin 1
Second 12 Volts N/A
Starter purple + Certification ECU right of dash fuse box, white 16 pin plug, pin 10
Second Starter beige (SS1); gray (SS2) - Certification ECU right of dash fuse box, black 24 pin plug, pins 16, 18
Ignition black + Certification ECU right of dash fuse box, white 16 pin plug, pin 3
Second Ignition N/A
Third Ignition N/A
Accessory red + Certification ECU right of dash fuse box, black 24 pin plug, pin 9
Second Accessory N/A
Third Accessory N/A
Keysense lt. green - Certification ECU right of dash fuse box, white 16 pin plug, pin 8
Data Bus yellow (IMO); lt. blue (IMI) data Certification ECU right of dash fuse box, white 16 pin plug, pins 7, 6 Note 1
Can Bus High blue data data link connector, white 16 pin plug, pin 6
Can Bus Low white data data link connector, white 16 pin plug, pin 14
Can Bus Sw black (RDA keyless entry data) data Body ECU on dash fuse box, white 30 pin plug, pin 4
Power Lock red (w/o window jam protect); pink (w/jam protect) - driv kick, wh 13 pin plg, pin 9; dash FB, rear, wht 32 pin plg(1D), pin 10 Note 2
Power Unlock yellow (w/o jam protect); yellow (w/jam protect) - drv kick, wh 13 pin plg, pin10; dash FB, rear, wht 32 pin plg(1D), pin 26 Note 3
Lock Motor blue 5 wire driver kick, gray 10 pin plug, pin 9
Driver Unlock Motor black 5 wire driver kick, gray 10 pin plug, pin 10
Passenger Unlock Motor green 5 wire dash fuse box, rear, white 32 pin plug (1D), pin 3
Parking Lights (-) green - Body ECU on dash fuse box, white 30 pin plug, pin 22
Parking Lights (+) green + dash fuse box, white 32 pin plug (1F), pin 3
Hazards yellow - A/C Control Assembly, black 16 pin plug, pin 4
Turn Signal (Left) beige (F); yellow (R) + above driv kick, blk 18P plg, pin 18; dash FB, wht 32 pin plg (1F), pin 6
Turn Signal (Right) lt. blue (F); lt. blue (R) + above pass kick, wh 13P plg, pin13; dash FB, wht 32 pin plg (1F), pin 7
Headlight yellow - Body ECU on dash fuse box, white 30 pin plug, pin 12
AutoLights white (interrupt to turn off autolights) - Body ECU on dash fuse box, white 30 pin plg, pin 8
Reverse Light red + above driver kick, white 18 pin plug, pin 5
Left Front Door Trigger yellow - Body ECU on dash fuse box, white 30 pin plug, pin 6
Right Front Door Trigger lt. green - Body ECU on dash fuse box, wht 30 pin plug, pin 27
Left Rear Door Trigger pink - dash fuse box, white 36 pin plug (1H), pin 36
Right Rear Door Trigger purple - dash fuse box, rear, white 32 pin plg (1D), pin 30
Dome Supervision beige - dash fuse box, rear, white 32 pin plug (1D), pin 29
Trunk/Hatch Pin N/A
Rear Glass Pin N/A
Hood Pin purple - Body ECU on dash fuse box, white 30 pin plug, pin 11
Trunk/Hatch Release N/A
Trunk Release Motor N/A
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm lt. blue (driver door key lock) - driver kick, white 13 pin plug, pin 11
Factory Alarm Disarm green (driver door key unlock) double - driver kick, white 13 pin plug, pin 12
Disarm No Unlock (smart key and push-button)
Trunk Alarm Shunt N/A
Tachometer beige ac data link connector, white 16 pin plug, pin 9
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal N/A
Fuel Pump pink + below underhood fuse box, black 12 pin plug, pin 1
Rear Defroster N/A
Mirror Defroster black (+) latched driver kick, white 10 pin plug, pin 4
Left Front Heated Seat red + driver kick, white 18 pin plug, pin 10
Right Front Heated Seat lt. blue + passenger kick, white 18 pin plug, pin 7
Speed Sense purple ac radio, white 28 pin plug, pin 17
Brake Wire blue or lt. blue + brake switch, white 4 pin plug, pin 1
Parking Brake white - dash fuse box, rear, white 32 pin plug (1D), pin 21
Horn Trigger red to blue - horn switch or dash fuse box, white 32 pin plug (1F), pin 26
Wipers black (LO); green (HI); blue (ignition) + wiper switch, white 10 pin plug, pins 3, 4, 2
Left Front Window (Up/Down) lavender/blue - lavender/brown(w/o jam protection) A power window master switch, white 18 pin plug, pins 3 - 4
Right Front Window (Up/Down) green - purple (w/o jam protection) A driver kick, gray 10 pin plug, pins 3 - 4
Left Rear Window (Up/Down) lt. green - yellow A driver kick, gray 10 pin plug, pins 8 - 7
Right Rear Window (Up/Down) black - red A driver kick, gray 10 pin plug, pins 6 - 2
Sun Roof (Open/Close) black - lt. blue (function with ignition on only) - roof console assembly, white 24 pin plug, pins 19 - 18
Sun Roof (Limit/Close) N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12V white + radio, white 10 pin plug, pin 4
Radio Ground WHITE/ black - radio, white 10 pin plug, pin 7
Radio Ignition gray + radio, white 10 pin plug, pin 3
Radio Illumination green (parking lights); beige (dimmer) +,- radio, white 10 pin plug, pin 10; blue 6 pin plug, pin 5
Factory Amp Turn-on N/A
Power Antenna N/A
Left Front Speaker (+/-) lavender/black - lavender/white +,- radio, white 10 pin plug, pins 2 - 6 Note 4
Right Front Speaker (+/-) lavender/red - lavender/green +,- radio, white 10 pin plug, pins 1 - 5 Note 5
Left Rear Speaker (+/-) white - black +,- radio, blue 6 pin plug, pins 2 - 6 Note 6
Right Rear Speaker (+/-) blue - lt. green +,- radio, blue 6 pin plug, pins 1 - 3 Note 7
Center Channel (+/-) N/A
Subwoofer (+/-) lvndr/grn - lvndr/yel(1); lvndr/blk - lvndr/red(2) +,- amplifier on pass side rear cabin wall, wh 12 pin plg, pins 5-12; 4-10
Aux. Audio Input Left (+/-) black - red +,- radio, white 28 pin plug, pins 28 - 27
Aux. Audio Input Right (+/-) white - red +,- radio, white 28 pin plug, pins 26 - 27
RSE Video (+/-) red - white (rear view camera video) +,- radio, white 24 pin plug, pins 12 - 24
RSE Audio Left (+/-) N/A
RSE Audio Right (+/-) N/A
Satellite Radio 12 Volts red + satellite tuner below radio, wht 8 pin plug, pin 4
Satellite Radio Ground black - satellite tuner below radio, wht 8 pin plug, pin 8
Satellite Radio Ignition yellow + satellite tuner below radio, wht 8 pin plug, pin 3
Satellite Radio Antenna (coaxial cable)
Satellite Audio Left (+/-) (DIN cable)
Satellite Audio Right (+/-) (DIN cable)
Headunit double DIN center of dash
Left Front Speaker left front door
Left Front Tweeter left front dash
Right Front Speaker right front door
Right Front Tweeter right front dash
Left Rear Speaker left rear door
Left Rear Tweeter N/A
Right Rear Speaker right rear door
Right Rear Tweeter N/A
Center Channel N/A
Subwoofer passenger side rear cabin wall
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner below radio
NOTES
1.The security light is purple (+) at the Certification ECU right of dash fuse box, black 24 pin plug, pin 19.
2.Test with passenger door switch on models with window jam protection.
3.Test with passenger door switch on models with window jam protection.
4.On models with amplifier, the speaker wires are green - lt. green (woofer); yellow - red (tweeter) at the amplifier on passenger side rear cabin wall, white 12 pin plug, pins 2 - 1; black 10 pin plug, pins 8 - 7.
5.On models with amplifier, the speaker wires are gray - blue (woofer); pink - purple (tweeter) at the amplifier on passenger side rear cabin wall, white 12 pin plug, pins 9 - 3; black 10 pin plug, pins 2 - 6.
6.On models with amplifier, the speaker wires are white - black at the amplifier on passenger side rear cabin wall, black 10 pin plug, pins 3 - 9.
7.On models with amplifier, the speaker wires are lavender/blue - lavender/lt. green at the amplifier on passenger side rear cabin wall, black 10 pin plug, pins 10 - 4.
Search the12volt.com |
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
