2011 Chevrolet Equinox, Alarm/Remote Start Wiring
lurch228
Silver - Posts: 1,338
Posted: September 15, 2016 at 12:22 AM / IP Logged
Directwire
2011 Chevrolet Equinox - North America
Remote Start, Security, Keyless Entry, Accessories
Item Wire Color Polarity Wire Location
12 Volts RED / white (30A) + BCM under driver dash, blue 27 pin plug, pin 4
Starter purple (for starter kill only) + starter motor or underhood fuse box, gray 40 pin plug (X1), pin B3
Second Starter pink (r-code); WHITE/ black (5V ref)(Tech Doc 1605) +9600 ohms ignition switch or BCM under driver dash, green 25 pin plg, pins 15, 22
Ignition pink + ignition switch or BCM under driver dash, green 25 pin plug, pin 6
Accessory brown + ignition switch or BCM under driver dash, green 25 pin plug, pin 5
Second Accessory (same as second starter) +6300 ohms
Keysense (same as second starter)
Data Bus lt. blue (immobilizer LIN bus) data immobilizer module or BCM under driver dash, green 25 pin plg, pin 2
CAN Bus High tan/black (high speed GMLAN) data data link connector or BCM under driver dash, blue 27 pin plg, pin 24
CAN Bus Low tan (high speed GMLAN) data data link connector or BCM under driver dash, blue 27 pin plg, pin 23
CAN Bus SW dk. green (low speed GMLAN) data data link connector or BCM under driver dash, blue 27 pin plg, pin 22
Power Lock pink/black - BCM under driver dash, blue 27 pin plug, pin 19
Power Unlock ORANGE / black - BCM under driver dash, blue 27 pin plug, pin 15
Lock Motor dk. green (for OEM sec upgrade, see Tech Doc 1925) 5 wire BCM under driver dash, pink 27 pin plug, pin 4
Driver Unlock Motor gray 5 wire BCM under driver dash, pink 27 pin plug, pin 1
Passenger Unlock Motor tan 5 wire BCM under driver dash, pink 27 pin plug, pin 2
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock (Passkey and ignition)
Parking Lights (+) purple (LF); brn/wht (RF); brown (LR); brown (RR) + BCM under dr dash, blk 26 pin plg, pins 6, 5, 7; brn 26 pin plug, pin 7
Parking Lights (-) lt. blue - BCM under driver dash, white 26 pin plug, pin 22
Hazards white - BCM under driver dash, blue 27 pin plug, pin 26
Turn Signal (Left) lt. blue/white (F); yellow/black (R) + BCM under driver dash, brown 26 pin plug, pins 2, 1
Turn Signal (Right) dk. blue/white (F); dk. GREEN / WHITE (R) + BCM under driver dash, black 26 pin plug, pins 3, 4
Headlight white (also need to trigger parking lights (-)) - BCM under driver dash, white 26 pin plug, pin 16
AutoLights dk. green (ground to turn off) - BCM under driver dash, white 26 pin plug, pin 11
Reverse Light lt. green + BCM under driver dash, gray 26 pin plug, pin 3
Left Front Door Trigger gray/black - driver window switch, black 8 pin plug, pin 6
Right Front Door Trigger tan/white - passenger window switch, black 8 pin plug, pin 6
Left Rear Door Trigger lt. blue/black - left rear window switch, black 8 pin plug, pin 2
Right Rear Door Trigger lt. GREEN/ black - right rear window switch, black 8 pin plug, pin 2
Dome Light gray + BCM under driver dash, gray 26 pin plug, pin 1
Trunk/Hatch Pin pink/blk (w/o pwr liftgt); pink/blk (w/pwr liftgt) - BCM, pk 27 pin plg, pin 5; Liftgate Mod in liftgate, bk 16 pin plg, pin 5
Hood Pin pink/black - BCM under driver dash, black 26 pin plug, pin 24
Trunk/Hatch Release gray (rear handle sw); gray/black (power liftgate) - BCM, pink 27 pin plug, pin 15; pwr liftgate switch, blk 4 pin plug, pin 4
Trunk Release Motor lt. blue (without power liftgate) 5 wire driver kick, harness to rear
Tachometer brn, dk. blue, dk. grn, lt. blue, lt. grn, or pur ac any fuel injector, black 2 pin plug, pin 1
Fuel Pump pink + driver kick, harness to rear
Rear Defroster white + latched above driver kick, black 43 pin plug, pin 8
Mirror Defroster (same as rear defroster)
Left Front Heated Seat (low speed GMLAN)
Right Front Heated Seat (low speed GMLAN)
Speed Sense dk. GREEN / WHITE (some models only) ac radio, gray 20 pin plug, pin 20
Brake Wire white + BCM under driver dash, black 26 pin plug, pin 11
Parking Brake lt. blue - BCM under driver dash, pink 27 pin plug, pin 12
Horn Trigger tan - BCM under driver dash, brown 26 pin plug, pin 19
Wipers gray + BCM under driver dash, black 26 pin plug, pin 16
Left Front Window (Up/Down) dk. blue - brown A driver window switch, black 8 pin plug, pins 2 - 3
Right Front Window (Up/Down) dk. blue - brown A passenger window switch, black 8 pin plug, pins 2 - 3
Left Rear Window (Up/Down) dk. blue - brown A left rear window switch, black 8 pin plug, pins 6 - 7
Right Rear Window (Up/Down) dk. blue - brown A right rear window switch, black 8 pin plug, pins 6 - 7
Sun Roof (Open/Close) lt. blue (open) (functions with ignition on only) - 100 ohms sunroof switch, black 4 pin plug, pin 4
Sun Roof (Limit/Close) (close) (same as sun roof open) - 940 ohms
Memory Seat 1 white - 630 ohms memory seat switch, black 6 pin plug, pin 6
Memory Seat 2 (same as memory seat 1) -2000 ohms
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
