Viper 5305v direct wire info Opel vectra 2006
Posted: September 30, 2016 at 2:27 PM / IP Logged Link to Post Post Reply Quote howie ll
That will work but position is critical, try it with that key at least three times with the regular key well away from the car.
chrisj000
Member - Posts: 38
Posted: September 30, 2016 at 3:11 PM / IP Logged Link to Post Post Reply Quote chrisj000
Will do,il post back and let you know how I get on,thanks for your time
chrisj000
Member - Posts: 38
Posted: October 01, 2016 at 2:01 PM / IP Logged Link to Post Post Reply Quote chrisj000
Small update,the missus went out for the afternoon so thought I'd tidy the mess I'd made while trying to get this work,all unused wires cut shorter with heat shrink to insulate the ends all other confirmed connections soldered and heat shrinked,pressed the remote start button to check everything worked as before and for some reason the car started without the key in the ignition,the key was just placed on top of cim module,I must of had a bad connection somewhere or interfance from one of the other unconnected wires
Posted: October 01, 2016 at 2:23 PM / IP Logged Link to Post Post Reply Quote howie ll
Good!
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
