2001 Sierra 2500
Welcome Guest :)
ziggyb222
Silver -
Posted: October 08, 2016 at 6:50 PM / IP Logged
Installed a Avital 4103 in a GMC Sierra. Done a ton of these... In remote start and with the key.... the ABS and Brake light come on after about 20 seconds of running...Ignition wires timing?????
beegbie
Copper -
Posted: October 08, 2016 at 7:51 PM / IP Logged
Did you power up the correct accessory? Should only need one along with two ignitions. I've heard that both accessories may need to be powered up but never experienced it myself.
ziggyb222
Silver -
Posted: October 08, 2016 at 9:49 PM / IP Logged
I dont think I have ever powered up the brown acc. wire...
lurch228
Silver -
Posted: October 09, 2016 at 1:43 AM / IP Logged
ziggyb222 wrote:
Installed a Avital 4103 in a GMC Sierra. Done a ton of these... In remote start and with the key.... the ABS and Brake light come on after about 20 seconds of running...Ignition wires timing????? |
It's having this issue with the key also?
ziggyb222
Silver -
Posted: October 09, 2016 at 7:47 AM / IP Logged
Yes when started with the key also. going to look at it again today...Everything is soldered also...
ziggyb222
Silver -
Posted: October 09, 2016 at 9:57 AM / IP Logged
Found the issue...Appears to have been a cold soldered joint on the primary ignition wire... Resoldered it and checked all other connections and works as it should now....Thanks for your responses!!!!
lurch228
Silver -
Posted: October 09, 2016 at 5:55 PM / IP Logged
Did the Ignition wire get cut, as a bad soldered tie wont usually case this with the key?
If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
Friday, April 19, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
