acura mdx door locks
bogucki
Copper - Posts: 91
Posted: October 11, 2016 at 12:35 PM / IP Logged Link to Post Post Reply Quote bogucki
hey guys, just wanted to check with you all. I have a acura mdx and direct-techs/driect wire   says only door lock / unlock wires are in the drivers door panel, just wondering if you know another area where i can get the door lock wires with out taking the door panel off and running wires to the door ?
thanks
boguckialex
lurch228
Silver - Posts: 1,338
Posted: October 11, 2016 at 1:20 PM / IP Logged Link to Post Post Reply Quote lurch228
Newer vehicles have data bus modules in each door. If you don't want to wire into the door you other option is a convenience bypass for the door locks.
bogucki
Copper - Posts: 91
Posted: October 11, 2016 at 3:23 PM / IP Logged Link to Post Post Reply Quote bogucki
i was wanting to use the fortin bypass and its diagram says to hook up the door locks to the bypass modual i was just hoping there was wires on the inside of the car so i dont have to go through the door boot and into the door
boguckialex
lurch228
Posted: October 11, 2016 at 6:24 PM / IP Logged Link to Post Post Reply Quote lurch228
1)Which module?
2)And which door locks the vehicle or the alarm or Remote start lock wires?
bogucki
Copper - Posts: 91
Posted: October 11, 2016 at 6:32 PM / IP Logged Link to Post Post Reply Quote bogucki
the module is the fortin evo-all heres the link to the install guide https://fortin.ca/download/57531/evo-all_ig_reg_bi_hon_mdx-crv_2007-2013_a_57531.pdf
it wants to me wire the door lock and unlock wires from the fortin evo-all bypass to the acura door lock wire found in the drivers door , and i really did not want to take the door apart and fish wire through the door boot and drill/make a hole in the door harness connector the get the wires through. so i was hoping there was lock and unlock wires found inside the car like in the kick panel or bcm but a can't find ant info on that, as direct wire is saying to to the door lock switch found in the door :(
boguckialex
beegbie
Copper - Posts: 341
Posted: October 11, 2016 at 7:48 PM / IP Logged Link to Post Post Reply Quote beegbie
I just looked at the guide. It specifically says "no connection" (actually no connexion") for the door locks on the MDX. Only the crv requires the door lock connections.
lurch228
Posted: October 11, 2016 at 8:10 PM / IP Logged Link to Post Post Reply Quote lurch228
So unless the door locks won't work while engine is running you should be .
bogucki
Copper - Posts: 91
Posted: October 11, 2016 at 8:25 PM / IP Logged Link to Post Post Reply Quote bogucki
wow i feel dumb now lol i dont know how i missed that.
thanks guys
boguckialex
lurch228
Posted: October 11, 2016 at 8:51 PM / IP Logged Link to Post Post Reply Quote lurch228
The simplest things are often over looked.
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
