12 Volts red (60A) + dash fuse box, rear, white 4 pin plug, pin 3
Starter WHITE/ black + dash fuse box, brown 12 pin plug, pin 10
Second Starter red (SS1); black (SS2) - push button ignition switch, black 14 pin plug, pins 7, 2
Ignition gray/red + dash fuse box, white 8 pin plug, pin 4
Second Ignition blue/red + dash fuse box, brown 12 pin plug, pin 12
Accessory green + dash fuse box, brown 12 pin plug, pin 2
Data Bus RED / white (immobilizer communication) data ECM on passenger side of engine,
bottom, black 65 pin plug, pin 38
Also found RED / white at junction connector behind dash fuse box, white 86 pin plug, pin 44.
CAN Bus High red (Body CAN); red (Main CAN) data dash fuse box, rear, wht 32 pin plg, pin 31; rear, wht 40 pin plg, pin 22
CAN Bus Low blue (Body CAN); blue (Main CAN) data dash fuse box, rear, wht 32 pin plg, pin 15; rear, wht 40 pin plug, pin 2
Power Lock BROWN / white - driver kick, white 46 pin plug, pin 24
Power Unlock BROWN / black - driver kick, white 46 pin plug, pin 15
Lock Motor lt. GREEN/ YELLOW 5 wire dash fuse box, white 8 pin plug, pin 6
Driver Unlock Motor blue/green 5 wire driver kick, white 46 pin plug, pin 4
Passenger Unlock Motor RED / black 5 wire dash fuse box, white 8 pin plug, pin 2
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock (proximity key and push-button)
Parking Lights (+) BLACK/ green + dash fuse box, blue 16 pin plug, pin 5
Parking Lights (-) black - headlight switch, white 20 pin plug, pin 18
Hazards green - dash fuse box, rear, white 40 pin plug, pin 37
Turn Signal (Left) BLACK/ green (F); blue / YELLOW (R) + dash fuse box, rear, blk 8 pin plug, pin 3; rear, white 10 pin plug, pin 1
Turn Signal (Right) RED / green (F); RED / green (R) + dash fuse box, rear, blk 8 pin plug, pin 8; rear, white 10 pin plug, pin 5
Headlight GREEN / WHITE - headlight switch, white 20 pin plug, pin 20
AutoLights orange (interrupt to turn off) - headlight switch, white 20 pin plug, pin 19
Reverse Light BROWN / yellow + dash fuse box, blue 16 pin plug, pin 3
Left Front Door Trigger pink - driver kick, blue 18 pin plg, pin 6 or dash FB, rear, wh 40 pin plg, pin33
Right Front Door Trigger blue/orange - dash fuse box, rear, white 40 pin plug, pin 13
Left Rear Door Trigger lt. green - dash fuse box, rear, white 40 pin plug, pin 14
Right Rear Door Trigger gray - dash fuse box, rear, white 40 pin plug, pin 34
Dome Light brown - dash fuse box, rear, white 10 pin plug, pin 9
Trunk/Hatch Pin lt. GREEN/ black - dash fuse box, rear, white 40 pin plug, pin 15
Hood Pin yellow/black (with remote start only) - Remote Start Mod jumper harness above driv kick, wht 8 pin plg, pin 5
Trunk/Hatch Release blue/green - trunk release switch, gray 4 pin plug, pin 1
Trunk Release Motor purple 5 wire dash fuse box, white 12 pin plug, pin 7
Tachometer BROWN / blk, blue/blk, purple, or BROWN / wht (4-cyl) ac ECM on pass side of engine, top, blk 65 pin plug, pin 23, 8, 9, or 22
Fuel Pump RED / black + passenger kick, white 4 pin plug, pin 4
Rear Defroster PURPLE / green - latched dash fuse box, rear, white 32 pin plug, pin 21
Mirror Defroster (mirror same as rear defrost); pnk/grn (wpr deice) - latched dash fuse
box, rear, white 32 pin plug, pin 18
Left Front Heated Seat (LIN bus)
Right Front Heated Seat (LIN bus)
Speed Sense GREEN / WHITE ac radio, white 28 pin plug, pin 17
Brake Wire BROWN / white + brake switch, white 5 pin plug, pin 2
Parking Brake WHITE/ green - electric parking brake switch, white 12 pin plug, pin 12
Horn Trigger red - horn switch, white 14 pin plug, pin 9
boguckialex
