Auto up and down on 3 wire power windows
emperorbrownsug
Posted: November 18, 2016 at 11:14 PM / IP Logged Link to Post Post Reply Quote emperorbrownsug
Seeing if anyone had an idea or diagram I could borrow to add one touch up and down features to an old gm 3 wire power window setup. The problem I'm having is the aftermarket units dei or autoloc are setup for the 5 wire type with the switching ground. The motors on the old cars ground themselves at the mounting points on the door. Any ideas or help would be appreciated thanks in advance.
emperorbrownsug
Posted: November 18, 2016 at 11:15 PM / IP Logged Link to Post Post Reply Quote emperorbrownsug
Car is a 1977 chevy monte carlo
Posted: November 19, 2016 at 5:15 PM / IP Logged Link to Post Post Reply Quote howie ll
Test the wiring at the switches. If one goes to ground and the other goes to 12V+ for one direction then they change over for the other direction, then use what DEI call type "A".
Ween
Platinum - Posts: 1,366
Posted: November 19, 2016 at 5:20 PM / IP Logged Link to Post Post Reply Quote Ween
Some info here https://www.the12volt.com/installbay/forum_posts.asp?tid=133932
Posted: November 22, 2016 at 4:41 PM / IP Logged Link to Post Post Reply Quote howie ll
Thanks Ween I've finally got it as well!
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
