Will 535T work with 06 Silverado?
tdbaker021
Copper - Posts: 98
Posted: December 18, 2016 at 4:00 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Will the 535T work with the 06 Silverado? I'm installing an Excalibur 2060 and was going to use the 535T. I bought the 535T (for the one touch) and I also have two AU-93. The alarm is pretty much benched prepped except for the window modules. Has anyone used the AutoLoc WC2000? That would be my next choice so the truck will have auto up and down.
tdbaker021
Copper - Posts: 98
Posted: December 24, 2016 at 2:14 AM / IP Logged Link to Post Post Reply Quote tdbaker021
I'm guessing no one knows!? It's funny how everyone says this is the best place for help on installs but no one ever replies to the post. Guess I'll find out when I do the install next week!!
tdbaker021
Copper - Posts: 98
Posted: January 12, 2017 at 11:52 PM / IP Logged Link to Post Post Reply Quote tdbaker021
I guess no one uses window automation on here!!! I'm glad to see I'm not the only one whos new to this!!
jap1975
Member - Posts: 12
Posted: January 20, 2017 at 6:40 AM / IP Logged Link to Post Post Reply Quote jap1975
At last what did you do for window automation tdbaker?
Hi doing myself will bring great happiness and satisfaction even at the cost of time.
tdbaker021
Copper - Posts: 98
Posted: January 20, 2017 at 12:50 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Well I tried the DEI 535T, Au-93's, and Autolocs WC-1000. None of these would work on the truck. Either the window would move an inch or so or it would move a 1/16 of an inch. The DEI 535T had the best progress but it seemed like it didn't have enough power and the window would stop about halfway up. I found a DEI 530T and it should be here tomorrow. From my research this one has the most probability of working in my 06 Silverado.
Mark Mizenko
Copper - Posts: 460
Posted: January 20, 2017 at 10:19 PM / IP Logged Link to Post Post Reply Quote Mark Mizenko
You need to make sure you make good ground connections, inside the vehicle. And use 10 or 8 gauge wire for power to the window module or it will not work properly (as you described). I think you need to wire right at the motor on that vehicle.
Window automation modules require a lot of current when the key is off
tdbaker021
Copper - Posts: 98
Posted: January 20, 2017 at 11:26 PM / IP Logged Link to Post Post Reply Quote tdbaker021
+ & - 8 gauge wire from the battery from the start. was also wired between the motor and the switch. It simply will not work on this truck! I will try the 530T and hope the dip switches will help provide the power needed to roll the window up. I'll let ya know. I have yet to see anyone who has had success with window automation on a 03-06 Silverado...
tdbaker021
Copper - Posts: 98
Posted: January 21, 2017 at 4:11 PM / IP Logged Link to Post Post Reply Quote tdbaker021
After all the window modules I've tried the 530T works perfectly!!!
Mark Mizenko
Copper - Posts: 460
Posted: January 21, 2017 at 8:29 PM / IP Logged Link to Post Post Reply Quote Mark Mizenko
Good to hear that!
tdbaker021
Copper - Posts: 98
Posted: January 21, 2017 at 10:47 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Mark Mizenko wrote:
Good to hear that!
Really wished the 535T would work!! I like the wiring on it a lot better but I've tried everything and it just don't have enough juice to roll the windows up...
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
