2016 VW GTI - Avital 4115L w/ Dball2 Issue
guffaw
Member - Posts: 9
Posted: January 21, 2017 at 12:26 AM / IP Logged Link to Post Post Reply Quote guffaw
when I hooked the remote start up I originally only had one key, so I hooked everything up except the key wrap and it worked the first day. the second day it started having the issue before I got to do the key wrap, so the issue started before I was even able to complete the key wrap due to the lack of having the second key. I figured the issue was happening because I didn't complete the key wrap yet but completing the key wrap kept the same problem, just now I could use the remote start without having to have the good key in the car.
silvercivicsir
Copper - Posts: 402
Posted: January 21, 2017 at 12:36 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
there is not much to the install, and honestly if the car doesn't "attempt" to crank, it's 99.9% the key wrap/immobilizer (in my experience).. only other option I can suggest is swap out the DBALL, and try an Idatalink module
guffaw
Member - Posts: 9
Posted: January 21, 2017 at 12:39 AM / IP Logged Link to Post Post Reply Quote guffaw
it does attempt to start, I should post a video of it, the starter cranks for a half second and then cuts out, but it's not a virtual tach issue as I've tried to use voltage detect and just setting a crank time but no matter what it still cranks for half a second and then cuts out.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
