2007 Honda Element - Viper 4806V install
savagem
Member - Posts: 9
Posted: January 13, 2017 at 8:05 AM / IP Logged Link to Post Post Reply Quote savagem
kreg357 wrote:
Still have the wrong 6 Pin Main connector. Only difference is noted below :
H/3 BROWN (-) 200mA HORN HONK OUTPUT
This wire goes to the vehicles' Orange (-) horn wire.
Perhaps a typo. ACC2 is WHITE/ Red
VIPER 4806V - 8 Pin White Remote Start Heavy Gauge Connector
Pin01 - RED / Black - (+) FUSED 12V ACCESSORY/STARTER INPUT     White @ IGNITION SWITCH HARNESS
Pin02 - Pink/Black - (+) FLEX RELAY INPUT FLEX RELAY          NOT USED - PINOUT WIRE
Pin03 - Pink/White - (+) IGNITION 2 / FLEX RELAY OUTPUT       WHITE/ Red @ IGNITION SWITCH HARNESS   *set Flex to ACC2
Pin04 - Red - (+) FUSED 12V IGNITION 1 INPUT   White @ Ignition Harness
Pin05 - Violet - (+) STARTER OUTPUT            BLACK/ White @ Ignition Harness
Pin06 - Orange - (+) ACCESSORY OUTPUT          BLACK/ Red @Ignition Harness
Pin07 - RED / White - (+) FUSED 12V IGNITION 2 / FLEX RELAY     White @ IGNITION SWITCH HARNESS
Pin08 - Pink - (+) IGNITION 1 INPUT/OUTPUT     BLACK / YELLOW @ Ignition Harness
Just to confirm that:
1) Pin04 - Red - (+) FUSED 12V IGNITION 1 INPUT
2) Pin07 - RED / White - (+) FUSED 12V IGNITION 2 / FLEX RELAY
Are both connected to the White 12V Constant White wire at the ignition? Do I join all 3 wire before the connection to the vehicle.
I'll make the correction to my sheet. I had Pin 04 to BLACK / YELLOW.
Platinum - Posts: 7,783
Posted: January 13, 2017 at 8:51 AM / IP Logged Link to Post Post Reply Quote kreg357
Due to the current, I would try to run all 3 thick fused Viper wires to the Element's White Power wire and make 3 connections there. Another possible way is to join the thick Red and the thinner Red about 3 inches from the White connection and then make one solder connection there. Same for the RED / White and RED / Black, join them 3 inches from the White wire and then just one connection to the White wire. Leave the fuses in place.
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
