Latching Relay Circuit With One Momentary Switch
davidhaller
Member - Posts: 16
Posted: January 26, 2017 at 2:46 PM / IP Logged Link to Post Post Reply Quote davidhaller
Hello, I have a keyless entry system on my car and it honks every time I lock the doors. I would like to use a latching relay to enable and disable it to honk. I want to use a momentary switch for this. How can I do this?
the12volt
Administrator - Posts: 3,955
Posted: January 26, 2017 at 3:39 PM / IP Logged Link to Post Post Reply Quote the12volt
You may be better off just using a hidden toggle switch so you do not run down your battery, but you can have a look at the latching relay diagrams here: https://www.the12volt.com/relays/relaydiagrams.asp
Latching Relay Circuit With One Momentary Switch - Last Post -- posted image. the12volt • Support the12volt.com
davidhaller
Member - Posts: 16
Posted: January 26, 2017 at 4:23 PM / IP Logged Link to Post Post Reply Quote davidhaller
I want to use a momentary switch because it is slim line.
the12volt
Posted: January 26, 2017 at 5:45 PM / IP Logged Link to Post Post Reply Quote the12volt
Instead of using multiple relays to create a latch, I'd find a latching relay like the one seen here: https://www.the12volt.com/relays/page5.asp#sppbdl
davidhaller
Member - Posts: 16
Posted: January 27, 2017 at 10:08 AM / IP Logged Link to Post Post Reply Quote davidhaller
Is there a way to do this but with one relay?
the12volt
Posted: January 27, 2017 at 10:57 AM / IP Logged Link to Post Post Reply Quote the12volt
Yes, use a latching relay. Each time you activate the coil of a latching relay, it will change the contacts from closed to open if the contacts were closed, and from open to closed if the contacts were open.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
