99 tahoe pljx
whitty121
Posted: February 04, 2017 at 3:44 PM / IP Logged Link to Post Post Reply Quote whitty121
Hi everyone.
My passlock system is playing up on my tahoe, right now I have a 10k resistor hooked into it to help it start, which it does but if left for more than an hour I need to wait 10 minutes. Most likely because the resistor isn't the right one ( I have no RadioShack near me ( Danville va ) so I used one out of an old tv )
I've decided an override box would be worth a try, I've bought the xprresskit pljx box. Which comes with no instructions.
I've managed to find an install guide on the net which looks easy enough, it does leave one question though....
The yellow passlock wire, at the moment I've cut it to install the resistor, do I reconnect it or do I leave it cut and wire the bypass to the cable the same as the resistor method.
Thank you for any help
Platinum - Posts: 7,783
Posted: February 04, 2017 at 7:37 PM / IP Logged Link to Post Post Reply Quote kreg357
Why not eliminate the Passlock2 system? You can even use the 10k ohm resistor. Here is a post with the instructions:
https://www.the12volt.com/installbay/forum_posts.asp?tid=123309&kw=racing_bidule
whitty121
Posted: February 05, 2017 at 10:58 AM / IP Logged Link to Post Post Reply Quote whitty121
That's what I've got at the moment, it works but it's not great, I have to do the relearn quite a lot, I think the resistor is rubbish, it's from an old crt tv and must be 25 years old lol
Posted: February 05, 2017 at 4:48 PM / IP Logged Link to Post Post Reply Quote kreg357
Switch to an other resistor, preferable one below 2k with at least a Gold tolerance band ( 5% ). Here is a link to a resistor
band color chart. http://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-resistor-color-code-4-band
Gold should be OK but if you can find one with Brown ( 2% ), Red (1% ) or Grey ( .5% ) that would be even better. I always
solder them in with heatshrink covering the resistor and connections.
A data style bypass module would be the best bet. I'd go with an iDatalink ADS TBSL PL bypass module. You could hardwire
the +12V & Chassis ground and use Keysense as the GWR input. Here is the Keysense info :
Keysense      Light GREEN (-)              @ 48 PIN CONN. TO LEFT OF STEERING COLUMN
Here is a link the ADS TBSL PL install guide :
https://images.idatalink.com/corporate/Content/Manuals/TB-PL/ADS-TBSL-PL_20110120.pdf
whitty121
Posted: February 06, 2017 at 9:52 PM / IP Logged Link to Post Post Reply Quote whitty121
That looks a bit like the xpresskit pljx box I have.
I can install it easy enough I just don't know what to do with the yellow passlock wire, leave it cut and wire it into the box or reconnect it back together and tap into it.
The whole system on my tahoe is crap, the security light never goes off now. It's one of the worse systems I've ever come across.
Posted: February 07, 2017 at 2:23 AM / IP Logged Link to Post Post Reply Quote kreg357
The iDatalink ADS TBSL PL does not connect or use the Yellow Passlock2 wire at all. It's a Data style bypass and connects to the J1850 wire at the ODB2 plug. The PLJX connects to the Yellow Passlock2 wire and the Passlock reference wire.
Passlock2 can be a PITA. Beside the ignition cylinder going bad, I've seen where a bad engine ground can throw them off.
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
