Setting up remote controlled lights
khill
Posted: February 13, 2017 at 10:26 AM / IP Logged Link to Post Post Reply Quote khill
The remote control has 8 functions. All of the functions are a momentary function. I'm trying to set up a LED work light on/off functions with the same button. This is a 24 volt system. The remote is also positive trigger not negative as in most cases.
I'm looking for the smallest relay possible.
I found a solid state option from IDEC but dimensions are out of my range.
http://www.clrwtr.com/PDF/IDEC/IDEC-RSS-Series-Relays.pdf
Thanks in advance.
mpheyse
Posted: February 21, 2017 at 3:11 PM / IP Logged Link to Post Post Reply Quote mpheyse
Relay Size has a lot to do with:
Switched Amps, Size of contacts
Switched Voltage, Distance the Contacts must travel through space.
How much current and voltage are trying to switch (your LED Lights ratinges)?
I'm assuming the 24V is the Remotes output?
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
