'17 nissan xtrail starter kill or kill switch?
josipeiro
Posted: February 17, 2017 at 1:04 PM / IP Logged Link to Post Post Reply Quote josipeiro
Hi, i got a nissan xtrail 17, is the same from the 15, the question is that i never install a kill switch or starter kill to a vehicle that star with keybutton/smartkey. I think the nissan xtrail is not sale in USA. so it could help if some want describe how is done in the nissan rogue 2015, is almost the same. i really don want to mess with the vcm or something like that, and not cutting cable by cable in the wiring from the starter button til it turn down the vehicle hahahaha.
hope you can help.
best regards
chev104275
Gold - Posts: 1,427
Posted: February 17, 2017 at 3:15 PM / IP Logged Link to Post Post Reply Quote chev104275
You could go directly to the starter motor and put a relay in the solenoid control wire.
Then control the relay however you want the kill switch to work. (Lights,window switch, directional) something along those lines
josipeiro
Posted: February 21, 2017 at 6:35 PM / IP Logged Link to Post Post Reply Quote josipeiro
Thks for the reply, but what i need is to shutdown the car remotely, i been searching how to do in the push-button ignition cars, i find in the nissan is in the "BMC" in the xtrail and in the sentra is in the driver kick panel, what a want to know is what cable shut i cut thru the relay to shutdown the car.
thks for the time
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
