AUX Window Wiring
pat0588
Member - Posts: 16
Posted: February 24, 2017 at 5:56 PM / IP Logged Link to Post Post Reply Quote pat0588
So im trying to get my windows to move up and down with the AUX wires attached my my Viper 5706V. However, when my windows roll up or down they use 12V. The AUX wires only give out about 0.3-0.4V which isnt enough to lower nor lift a window. Is there something im doing wrong? AUX Window Wiring -- posted image.
chev104275
Gold - Posts: 1,424
Posted: February 24, 2017 at 6:24 PM / IP Logged Link to Post Post Reply Quote chev104275
First of what kind of car are we working with ?
Second I would look into a 530T or 535T module
pat0588
Member - Posts: 16
Posted: February 24, 2017 at 6:48 PM / IP Logged Link to Post Post Reply Quote pat0588
Its a 98 grand prix. and i was under the impression that it was al built into the Viper 5706V and i didnt need to purchase the window modules
chev104275
Gold - Posts: 1,424
Posted: February 24, 2017 at 7:30 PM / IP Logged Link to Post Post Reply Quote chev104275
Hopefully Someone more familiar with your system will chime in. I have never seen a system with built in window controls. The system has aux outputs so it would be able to control window modules.
pat0588
Member - Posts: 16
Posted: February 25, 2017 at 3:22 AM / IP Logged Link to Post Post Reply Quote pat0588
I sure hope so. I couldnt find anything onlineAUX Window Wiring -- posted image.
sparkie
Platinum - Posts: 2,061
Posted: February 25, 2017 at 7:57 AM / IP Logged Link to Post Post Reply Quote sparkie
The aux outputs are negative triggers which cannot activate your power windows directly. You should use window modules as mentioned for safety reasons. The modules will activate 2 windows, so if you intend to do all 4 windows, you will need two modules. They are the safe way to activate the windows so as to prevent damage or injury if something restricts the window movements.
sparky
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
