2017 Hyundai Elantra Alarm/Remote Start, Stereo Wiring
yogs10
Posted: March 05, 2017 at 12:37 AM / IP Logged
Hi everybody, I was hoping someone would share Directed's wires car alarm for a 2017 hyundai elantra i want to install a viper alarm and i wanto to have references thanks in advance
tonanzith
Gold - Posts: 593
Posted: June 25, 2017 at 12:58 AM / IP Logged
2017 Hyundai Elantra - North America     DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     Green (40A)     +     Ignition Switch, black 6 pin plug, pin 1
Second 12 Volts     Red (40A)     +     Ignition Switch, black 6 pin plug, pin 5
Starter     White     +     Ignition Switch, black 6 pin plug, pin 3
Ignition     Pink     +     Ignition Switch, black 6 pin plug, pin 4
Accessory     Black     +     Ignition Switch, black 6 pin plug, pin 2
Second Accessory     Blue     +     Ignition Switch, black 6 pin plug, pin 6
Keysense     White     -     Key Switch, white 6 pin plug, pin 4
CAN Bus High     White (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low     Yellow (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus High 2     White (B-CAN)     Data     Dash Fuse Box, rear, white 32 pin plug (F), pin 17
CAN Bus Low 2     Brown (B-CAN)     Data     Dash Fuse Box, rear, white 32 pin plug (F), pin 18
IMMO Data     Brown/Orange (EMS COM)     Data     Driver Kick, black 82 pin plug, pin 29
K Line     Blue/Black     Data     OBD-Data Link Connector, black 16 pin plug, pin 12
Power Lock     Blue/Black (without memory); (use factory alarm arm, with memory)     -     Dash Fuse Box, white 32 pin plug (B), pin 31
Power Unlock     Yellow/Black (without memory); (use factory alarm disarm, with memory)     -     Dash Fuse Box, white 32 pin plug (B), pin 27
Power Unlock - Driver Door     Green     -     Driver Kick, black 82 pin plug, pin 78
Lock Motor     Gray     Reverse     Dash Fuse Box, white 38 pin plug (A), pin 27
Driver Unlock Motor     White     Reverse     Driver Kick, black 26 pin plug, pin 25
Passenger Unlock Motor     Brown     Reverse     Dash Fuse Box, white 38 pin plug (A), pin 2
Factory Alarm Arm     Gray/Black (driver door key lock); Green (detection) (see Tech Doc 1300)     - and Open     Dash Fuse Box, white 32 pin plug (B), pins 14, 15
Factory Alarm Disarm     Brown (driver door key unlock); Green (detection) (see Tech Doc 1300)     Both -     Dash Fuse Box, white 32 pin plug (B), pins 26, 15
Disarm No Unlock     (transponder and ignition)
Parking Lights (+)     Red/Orange (LF); Orange (RF); Green/Black (LR); Brown/Black (RR)     +     Dash Fuse Box, black 38 pin plug (D), pins 3, 10; white 38 pin plug (A), pins 14, 24
Parking Lights MUX     Blue     - 1680 Ohms     Headlight-Wiper Switch, black 16 pin plug, pin 14
Hazards     Red     -     Dash Fuse Box, rear, white 32 pin plug (F), pin 8
Turn Signal (Left)     Blue/Orange (F); Blue/Orange (R)     +     Dash Fuse Box, black 38 pin plug (D), pin 9; white 38 pin plug (A), pin 26
Turn Signal (Right)     Red/Orange (F); Red/Orange (R)     +     Dash Fuse Box, black 38 pin plug (D), pin 8; white 38 pin plug (A), pin 35
Headlight     Blue     - 5580 Ohms     Headlight-Wiper Switch, black 16 pin plug, pin 14
AutoLights     Blue     Cut     Headlight-Wiper Switch, black 16 pin plug, pin 14
Reverse Light     Blue     +     Driver Kick, black 82 pin plug, pin 31
Left Front Door Trigger     Brown     -     Dash Fuse Box, white 32 pin plug (B), pin 20
Right Front Door Trigger     Blue     -     Dash Fuse Box, white 32 pin plug (B), pin 21
Left Rear Door Trigger     Gray     -     Dash Fuse Box, white 32 pin plug (B), pin 12
Right Rear Door Trigger     Orange     -     Dash Fuse Box, white 32 pin plug (B), pin 13
Dome Light     Yellow     -     Left Front Pillar, white 36 pin plug, pin 6
Trunk/Hatch Pin     Green/Orange     -     Dash Fuse Box, white 32 pin plug (B), pin 16
Hood Pin     Green     -     Dash Fuse Box, black 38 pin plug (D), pin 25
Trunk/Hatch Release     Pink (rear handle switch)     -     Dash Fuse Box, white 32 pin plug (B), pin 22
Trunk Release Motor     Red     +     Dash Fuse Box, white 38 pin plug (A), pin 5
Tachometer     Green or White     ac     Camshaft Position Sensor on engine driver side, black 3 pin plug, pin 2
Clutch Pedal     White     +     Clutch Switch, black 4 pin plug, pin 1
Fuel Pump     Gray     +     Driver Kick, black 26 pin plug, pin 1
Rear Defroster     Black     - Latched     Dash Fuse Box, black 38 pin plug (D), pin 7
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     Brown     +     Driver Kick, white 48 pin plug, pin 19
Right Front Heated Seat     Blue     +     Passenger Kick, black 48 pin plug, pin 31
Speed Sense     White     ac     Radio, white 24 pin plug, pin 16 or white 38 pin plug, pin 38
Brake Wire     Blue/Orange     +     Driver Kick, black 82 pin plug, pin 28
Parking Brake     Orange     -     Dash Fuse Box, white 32 pin plug (B), pin 6
Horn Trigger     White     -     Driver Kick, black 82 pin plug, pin 57
Wipers     Red     +     Driver Kick, black 82 pin plug, pin 58
Left Front Window (Up/Down)     Orange - Yellow (with auto down only)     A     Power Window Main Switch, white 18 pin plug, pins 1 - 2
Right Front Window (Up/Down)     Brown - White (without memory); Yellow - Orange (with memory)     A     Driver Kick, door harness; Passenger Window Switch, white 24 pin plug, pins 3 - 4
Left Rear Window (Up/Down)     Blue - Orange (without memory); Yellow - White (with memory)     A     Driver Kick, door harness; Left Rear Window Switch, white 8 pin plug, pins 8 - 4
Right Rear Window (Up/Down)     Green - Yellow (without memory); Brown - Gray (with memory)     A     Driver Kick, door harness; Right Rear Window Switch, white 8 pin plug, pins 1 - 5
Sun Roof (Open/Close)     Orange/Black and Gray (open) (functions with ignition on only)     Both -     Overhead Console, white 8 pin plug, pins 5, 6
Sun Roof (Limit/Close)     Gray and Yellow (close) (functions with ignition on only)     Both -     Overhead Console, white 8 pin plug, pins 6, 7
Memory Seat 1     Yellow     -     Driver Kick, door harness
Memory Seat 2     Brown     -     Driver Kick, door harness
Radio 12V     Red     +     Radio, white 24 pin plug, pin 12 or white 35 pin plug, pin 10
Radio Ground     Black     -     Radio, white 24 pin plug, pin 24 or white 35 pin plug, pin 12
Radio Ignition     Blue     +     Radio, white 24 pin plug, pin 11 or 18 or white 35 pin plug, pin 22
Radio Illumination     Blue (parking lights); Gray (dimmer)     +,-     Radio, white 18 pin plug, pins 8, 17 or white 35 pin plug, pins 6, 19
Factory Amp Turn-on     (M-CAN)
Power Antenna     Red     +     Radio, white 18 pin plug, pin 18 or white 35 pin plug, pin 5
Left Front Speaker (+/-)     Orange - Blue     +,-     Radio, white 18 pin plug, pins 2 - 11 or white 38 pin plug, pins 13 - 14
On models with amplifier, the speaker wires are brown - white at the amplifier in trunk right side, black 28 pin plug, pins 4 - 19.
Right Front Speaker (+/-)     Green - Orange     +,-     Radio, white 18 pin plug, pins 3 - 12 or white 38 pin plug, pins 16 - 15
On models with amplifier, the speaker wires are yellow - black at the amplifier in trunk right side, black 28 pin plug, pins 3 - 18.
Left Rear Speaker (+/-)     Yellow - Black     +,-     Radio, white 18 pin plug, pins 1 - 10 or white 38 pin plug, pins 1 - 2
On models with amplifier, the speaker wires are orange - green at the amplifier in trunk right side, black 28 pin plug, pins 13 - 26.
Right Rear Speaker (+/-)     Brown - White     +,-     Radio, white 18 pin plug, pins 4 - 13 or white 38 pin plug, pins 28 - 27
On models with amplifier, the speaker wires are white - black or black - yellow at the amplifier in trunk right side, black 28 pin plug, pins 12 - 25.
Center Channel (+/-)     Yellow - Black     +,-     Amplifier in trunk right side, black 28 pin plug, pins 14 - 27
Subwoofer (+/-)     Brown - White (1); Red - Blue (2)     +,-     Amplifier in trunk right side, black 28 pin plug, pins 2 - 17; 1 - 16
Aux. Audio Input Left (+/-)     Gray - Black/Orange or Red - Black/Orange or Brown - Black/Orange     +,-     Radio, white 24 pin plug, pins 21 - 9 or white 38 pin plug, pins 24 - 25
Aux. Audio Input Right (+/-)     Blue - Black/Orange or Black - Black/Orange or Green - Black/Orange     +,-     Radio, white 24 pin plug, pins 8 - 9 or white 38 pin plug, pins 10 - 25
Rearview Camera Video     Red - Black     +,-     Radio, white 16 pin plug, pins 4 - 3 or white 38 pin plug, pins 7 - 21 or white 24 pin plug (C), pins 23 - 22
Satellite Radio 12 Volts     (built into radio)
Item     Size     Depth     Location
Headunit     irregular          center of dash
Left Front Speaker               left front door
Left Front Tweeter               left front door
Right Front Speaker               right front door
Right Front Tweeter               right front door
Left Rear Speaker               left rear door
Right Rear Speaker               right rear door
Center Channel               top center of dash
Subwoofer
Gary Sather
yogs10
Posted: June 25, 2017 at 1:58 AM / IP Logged
thank you tonanzith for the info
yogs10
Posted: June 25, 2017 at 3:06 AM / IP Logged
tonanzith i have a question in the info says power lock and unlock without memory use yellow/black and blue black but with a memory use a factory alarm and disarm but my question is what it means with a memory and no memory in the car, how can i identify if my car has memory or not
tonanzith
Gold - Posts: 593
Posted: June 25, 2017 at 11:00 AM / IP Logged
2017 Hyundai Elantra Alarm/Remote Start, Stereo Wiring -- posted image.
Gary Sather
yogs10
Posted: June 25, 2017 at 2:11 PM / IP Logged
So I just follow the diagram you post and the installation would be complete without worry about if my car has the memory that the wiring diagrams say
tonanzith
Gold - Posts: 593
Posted: June 25, 2017 at 9:51 PM / IP Logged
Yes. I would recommend using a module though. It would be much simpler. Not a beginner install.
Gary Sather
alphasnow
Posted: July 08, 2017 at 9:44 PM / IP Logged
All Products
Subwoofer
hey tonazith, I have a question, so as you know if you install LED turn signals, you will get hyperflashing. I'm trying to fix this by installing a resistor, the problem is that the turn signal bulb location is built into the lamp itself, I would have to splice into the wiring for the lamp itself to install resistors and keep the bulbs into the mounting housing for the unit itself, would you know anything about which two wires correspond to the turn signal for each lamp?
tonanzith
Gold - Posts: 593
Posted: July 08, 2017 at 10:59 PM / IP Logged
Off the top of my head no. I would have to open it up and use a meter.
Gary Sather
hyundaiguy
Posted: August 18, 2017 at 12:27 AM / IP Logged
Hi Tonanzith,
I just have a quick question. I managed to find all the wires for the speakers and subwoofer from my factory amplifier with the help of the wiring diagram you posted. So thank you so much for it!!! I noticed that in the diagram it says "factory amp turn-on (M-CAN)", what does that mean exactly? And if it's a wire, which one is it, and can I use it as a remote turn-on for aftermarket amplifiers?
KeepOnKeepingOn!
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
