Battery BLUE/YELLOW (+) IGNITION SWITCH HARNESS 1
Ignition 1 RED (+) IGNITION SWITCH HARNESS 2
Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS 4
Accessory 2 BLUE/BLACK (+) IGNITION SWITCH HARNESS 6
Starter 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS 5
Key Sense BLUE/RED (OPEN) IGNITION SWITCH HARNESS
WIRE RESTS AT (-) UNTIL KEY IS PUT IN IGNITION
Triggers
Wire Color Polarity Location Plug/Pin # Note Picture
All Doors
USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE
Front Left Door LIGHT GREEN (-) AT VEHICLE FUSE BOX
Front Right Door YELLOW (-) IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE IS PART OF THE VEHICLE FUSE BOX
Dome Light Supervision GREEN/ORANGE (-) AT VEHICLE FUSE BOX 3 PIN PLUG PIN #1
Dome Light 1 RED/GREEN (+) AT DOME LIGHT HARNESS
Dome Light 2 BLACK (-) AT DOME LIGHT HARNESS
Trunk/Hatch RED/YELLOW (-) IN HARNESS IN DRIVER KICKPANEL
ALSO LOCATED IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE THAT IS PART OF THE FUSE BOX PIN 62
Lighting
All Parking Lights GREEN/WHITE (+) AT VEHICLE FUSE BOX UNDER HOOD 15 PIN PLUG PIN #2
All Hazard Lights GREEN/YELLOW (-) AT HAZARD SWITCH
Low Beam Headlights ORANGE/BLUE & WHITE/RED (+) AT EACH HEADLIGHT
Brake Lights GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED/BLUE (+) IN HARNESS IN DRIVER KICKPANEL
Integration
Power Lock VIOLET OR VIOLET/WHITE (-) IN HARNESS IN DRIVER KICKPANEL
ALSO LOCATED IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE THAT IS PART OF THE FUSE BOX, WIRE IS VIOLET/WHITE AT ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE
Power Unlock LIGHT GREEN/RED (-) IN HARNESS IN DRIVER KICKPANEL
Driver Door Motor 1 BLUE/BLACK (REV) AT VEHICLE FUSE BOX
Driver Door Motor 2 BLUE/RED (REV) AT VEHICLE FUSE BOX
Passenger Door Motor 1 BLUE/ORANGE (REV) AT VEHICLE FUSE BOX
Passenger Door Motor 2 BLUE/RED (REV) AT VEHICLE FUSE BOX
Trunk Release WHITE (REV) IN HARNESS IN DRIVER KICKPANEL
Factory Alarm Arm LIGHT GREEN/BLACK (-) IN HARNESS IN DRIVER KICKPANEL
ALSO LOCATED IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE THAT IS PART OF THE FUSE BOX PIN 42, THIS WIRE WILL ALSO LOCK THE DOORS
Factory Alarm Disarm RED/GREEN (-) IN HARNESS IN DRIVER KICKPANEL
ALSO LOCATED IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE THAT IS PART OF THE FUSE BOX PIN 25, THIS WIRE WILL ALSO UNLOCK THE DOORS WITH A DOUBLE PULSE
Horn LIGHT GREEN (-) IN HARNESS AT STEERING COLUMN
Parking Brake YELLOW/GREEN (-) AT PARKING BRAKE SWITCH
Rear Window Defrost WHITE/BLACK (-) AT A/C CONTROL UNIT 27 OR 8 THIS WIRE ALSO CONTROLS HEATED MIRRORS IF EQUIPPED, PIN 27 ON MANUAL A/C UNITS, PIN 8 ON AUTOMATIC A/C UNITS
Rearview Mirror Accessory BLUE/RED (+) REARVIEW MIRROR HARNESS 1
Rearview Mirror Ground BLACK (-) REARVIEW MIRROR HARNESS 2
Low Speed Wipers BLUE/ORANGE (+) AT VEHICLE WIPER MOTOR
High Speed Wipers BLUE/RED (+) AT VEHICLE WIPER MOTOR
Power Top Open BLUE/WHITE (+) AT POWER TOP SWITCH
Power Top Close BLACK/ORANGE (+) AT POWER TOP SWITCH
OE Anti-Theft Information
Description
Anti Theft Name UNIVERSAL IMMOBILIZER
Anti Theft Type THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
OE Anti-Theft Wiring
Anti-Theft Reference WHITE/BLUE
ANTENNA RING AROUND KEY CYLINDER 3
Anti-Theft Signal BLACK/BLUE
ANTENNA RING AROUND KEY CYLINDER 7
Engine Wiring
Tach YELLOW/BLUE (AC) AT FUEL INJECTOR #1
ALSO YELLOW/RED AT INJECTOR #2
Speed Sense YELLOW/BLACK (AC) AT POWERTRAIN CONTROL MODULE 18 PIN PLUG PIN #14 GREEN/YELLOW ON AUTOMATIC TRANSMISSION VEHICLES 18 PIN PLUG PIN 17, POWERTRAIN CONTROL MODULE IS LOCATED IN THE FRONT OF THE ENGINE COMPARTMENT ON THE DRIVER SIDE
Safety Systems
Yes/No
Drivers Side Airbag Equipped YES
Passenger Side Airbag Equipped YES
Side Impact Airbag Equipped YES
