Remote Start, 2015 Nissan Versa
windog
Posted: March 14, 2017 at 6:36 PM / IP Logged Link to Post Post Reply Quote windog
Make
Nissan
Model
Versa Note
Year
2015
FUNCTION
DATACOLOR
LOCATION
POLARITY
12 Volts
pink (40A)
ignition switch, white 6 pin plug, pin 3
Second 12 Volts
N/A
Starter
white
ignition switch, white 6 pin plug, pin 2
Second Starter
N/A
Ignition
gray
ignition switch, white 6 pin plug, pin 1
Second Ignition
N/A
Third Ignition
N/A
Accessory
yellow
ignition switch, white 6 pin plug, pin 4
Second Accessory
lt. blue
ignition switch, white 6 pin plug, pin 5
Third Accessory
N/A
Keysense
red/blue to yellow
key switch, brown 2 pin plug, pin 1
Data Bus
pink (clock); lt. green (data)
NATS Antenna Amp on key switch, white 4 pin plug, pins 2, 4
data
Can Bus High
blue
data link connector, white 16 pin plug, pin 6
data
Can Bus Low
pink
data link connector, white 16 pin plug, pin 14
data
Can Bus Sw
N/A
Power Lock
gray
driver kick, door harn or BCM above driver kick, white 40 pin plg, pin 12
Power Unlock
brown
driver kick, door harn or BCM above driver kick, white 40 pin plg, pin 13 NB. These wires are top side of the connector which has to be disconnected to gain access. The electrical tape wraps a couple of harnesses- not just the door lock.
Lock Motor
lt. blue
driver kick, door harn or BCM above driver kick, white 15 pin plg, pin 14
5 wire
Driver Unlock Motor
green
driver kick, door harn or BCM above driver kick, white 15 pin plug, pin 1
5 wire
Passenger Unlock Motor
green
BCM above driver kick, white 15 pin plug, pin 13
5 wire
Parking Lights (-)
N/A
Parking Lights (+)
red
driver kick, white 24 pin plug, pin 3
Hazards
orange
hazard switch, white 4 pin plug, pin 2
Turn Signal (Left)
purple
driver kick, white 24 pin plug, pin 19
Turn Signal (Right)
white
driver kick, white 24 pin plug, pin 20
Headlight
blue (L); pink (R)
underhood fuse box, brown 8 pin plug, pins 6, 8
AutoLights
N/A
Reverse Light
lt. blue
driver kick, white 16 pin plug, pin 4
Left Front Door Trigger
lt. blue
driver kick, white 24 pin plug, pin 18
Right Front Door Trigger
orange
driver kick, white 24 pin plug, pin 17
Left Rear Door Trigger
white
driver kick, white 24 pin plug, pin 15
Right Rear Door Trigger
brown
driver kick, white 24 pin plug, pin 16
Dome Supervision
red
BCM above driver kick, white 15 pin plug, pin 5
Trunk/Hatch Pin
pink
driver kick, white 16 pin plug, pin 3
Rear Glass Pin
N/A
Hood Pin
N/A
Trunk/Hatch Release
(locks/unlocks along with doors)
Trunk Release Motor
N/A
Fuel Door Release
N/A
Power Sliding Door (Left)
N/A
Power Sliding Door (Right)
N/A
Factory Alarm Arm
gray (driver door key lock)
driver kick, door harn or BCM above driver kick, white 40 pin plug, pin 8
Factory Alarm Disarm
white (driver door key unlock)
driver kick, door harn or BCM above driver kick, white 40 pin plug, pin 7
double -
Disarm No Unlock
(see factory alarm disarm)
Trunk Alarm Shunt
N/A
Tachometer
blue, orange, green, or red
any fuel injector, black 2 pin plug, pin 2
ac
Wait to Start
N/A
Neutral Safety
N/A
Clutch Pedal
lt. green
clutch switch, brown 2 pin plug, pin 2
Fuel Pump
brown
driver kick, gray 16 pin plug, pin 5
Rear Defroster
green
rear defogger switch/HVAC control, black 15 pin plug, pin 10
Mirror Defroster
(same as rear defroster)
Left Front Heated Seat
yellow
LH heated seat switch, white 6 pin plug, pin 5
5 wire
Right Front Heated Seat
brown
RH heated seat switch, brown 6 pin plug, pin 5
5 wire
Speed Sense
lt. green
radio, white 20 pin plug, pin 18
8-Pulse
Brake Wire
lt. green or red
brake switch or driver kick, white 16 pin plug, pin 9
Parking Brake
lt. blue
parking brake switch, black 1 pin plug, pin 1
Horn Trigger
red
horn switch, yellow 6 pin plug, pin 1. WARNING! This wire is curiously located in the airbag connector at the steering cowl. Suggest use horn relay output in the underhood fuse box. Will require dismantling the said fuse box
Wipers
lt. green (LO); gray
the12volt
Administrator - Posts: 3,955
Posted: March 16, 2017 at 6:20 PM / IP Logged Link to Post Post Reply Quote the12volt
Thanks windog!
Remote Start, 2015 Nissan Versa -- posted image. the12volt • Support the12volt.com
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
