2017 Nissan Titan Unlock/Lock
tqwcs
Posted: April 03, 2017 at 6:37 PM / IP Logged Link to Post Post Reply Quote tqwcs
Hi,
I'm trying to wire up a cellularly connected microcontroller to remotely control the locks on a 2017 Nissan titan.
I have located the wires that I believe are involved in triggering lock/unlock. However, I'm not exactly sure what is happening so I'm not able to simulate lock/unlock being pressed with the microcontroller.
Here are some annotated images from the passengers side door.
2017 Nissan Titan Unlock/Lock -- posted image.
Any information about how the locks are controlled would be appreciated.
If there is any information missing let me know.
Twelvoltz
Platinum - Posts: 2,384
Posted: April 15, 2017 at 7:29 PM / IP Logged Link to Post Post Reply Quote Twelvoltz
On the 2017 Titan you'd use the analog alarm arm and disarm wires to control the locks. In the Driver's door at the power window switch, the white/red will pulse negative when you use the key in the door to the lock position, the black/white will show negative when turning the key to unlock. The unlock requires a double pulse to unlock all doors.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
