viper 4706 wiring 2001 silverado?
lime4x4
Member - Posts: 26
Posted: April 04, 2017 at 9:19 AM / IP Logged Link to Post Post Reply Quote lime4x4
Will be installing a viper 4706 remote start on a 2001 silverado with a diesel engine. Does anyone by chance have a wiring diagram as to what wires from the viper go where on the vehicle? Esp the 8 pin connector
Platinum - Posts: 7,781
Posted: April 04, 2017 at 9:46 PM / IP Logged Link to Post Post Reply Quote kreg357
Should be covered in this Pictorial :
https://www.the12volt.com/installbay/forum_posts.asp?tid=135786
lime4x4
Member - Posts: 26
Posted: April 18, 2017 at 7:15 PM / IP Logged Link to Post Post Reply Quote lime4x4
I got everything hooked up. Can the pink/black wire from the viper main 8 pin harness be used to power the brown accessory wire?
Posted: April 19, 2017 at 6:33 PM / IP Logged Link to Post Post Reply Quote kreg357
No. If you wish to power the Brown ACC2 wire you will need a 30/40 Amp SPDT relay with harness and inline fuse. You will use the Vipers thin Orange (-) Accessory Output wire to control the relay. I believe the relay wiring is also mentioned in the Pictorial.
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
