'01 Dodge Ram 1500 remote start for Avital 5305L
nytridr1
Posted: April 17, 2017 at 7:04 PM / IP Logged Link to Post Post Reply Quote nytridr1
I am hoping someone could help me out here. Need to know what wires goes were. So far I have had it to be able to attempt to start the truck, but that is all it will do. Seems like the fuel pump is not getting power or something, so I disconnected the remote start again and figured I would ask and see if someone can tell me which wires goes where.
Heres what I have for the heavy gauge wires.
Red/Black - + Fused 12v Accessory / Starter Relay input
Pink/Black - 2nd Ignition Accessory Isolation (Dont think I need this one)
Pink/White - + 2nd Ignition accessory relay output (20 of onboard relay)
Red - + Fused 12v Ignition 1 Relay input
Green and Violet are for the start wires.. (These two I know for sure(
Orange - + Accessory Output
Red/White - +Fused 12v 2nd Ignition Accessory Relay input 87
Pink - +Ignition 1 input / output
So far I have everything else working except the door locks.. (Which I have not yet started on, so I will work on those while I wait. Do I need any relays for the door locks for this, if so, which ones will work? )
Thank you
nytridr1
Posted: April 18, 2017 at 10:51 AM / IP Logged Link to Post Post Reply Quote nytridr1
So I re-hooked things up and it will try to start the truck but that is all it will do. If I turn the key on and they hit the remote start it will start, but the moment I turn the key off, it shuts off. its almost like the fuel system is not getting power or something.
Any ideas?
nytridr1
Posted: April 18, 2017 at 11:20 AM / IP Logged Link to Post Post Reply Quote nytridr1
Okay just incase anyone else comes across a problem like this, I did fix it. The PINK wire that is suppose to go to a blue wire in the truck was on the wrong blue wire. There was actually 2 blue wires.. one smaller and one larger. the larger one was behind everything so it was really hard to see. Both of these are just plain old blue.. not blue with a different color strip. Anyway the pink wire goes to the bigger blue wire.
I added the link to the detailed install manual below.. (This took me forever to find, but it is way better then the one that comes with it.)
http://www.directeddealers.com/manuals/IG/Avital/N5303_2008_07web_.pdf
Hopefully I have all the wires in the right places now.. all I now is it works now.
nytridr1
Posted: April 18, 2017 at 2:37 PM / IP Logged Link to Post Post Reply Quote nytridr1
a few more questions about this install..
Do I need relays for the door locks?
Do I need relays for the dome light?
How would I be able to roll up/down the windows?
Platinum - Posts: 7,783
Posted: April 19, 2017 at 9:44 PM / IP Logged Link to Post Post Reply Quote kreg357
You will need relays for the power door locks. Better yet get a Directed 451M module. They cost >$10, include a resistor pack ( you won't need ) and will plug right into the R/S. The door lock system is a 3/5 wire system, where the trucks Lock wire gets a straight +12V pulse and the Unlock wire is Type C. We can supply the actual wiring if you go with the 451M.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
