2017 Jeep Wrangler Unlimited Alarm/Stereo Wiring
genwmull77
Posted: April 25, 2017 at 9:11 PM / IP Logged
I am going to install an amp and sub and keep the factory deck. I need to know which wires coming out of the factory deck harness are for the rear (L/R) speakers. I also need to find a power wire that is only active with the ignition on to tap for the amps remote wire. Can anyone help?
tonanzith
Gold - Posts: 593
Posted: May 21, 2017 at 10:24 PM / IP Logged
North America     DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     red     +     battery or underhood fuse box
Second 12 Volts     lt. blue/red (10A only)     +     ignition switch, black 5 pin plug, pin 5
Starter     yellow/gray (for starter kill only)     +     starter or underhood fuse box, blue 26 pin plug, pin 8
Second Starter     purple/brown (use interface module or Tech Doc 1084)     - 180 ohms     ignition switch, black 5 pin plug, pin 2
Ignition     pink/white     +     ignition switch, black 5 pin plug, pin 3
Accessory     (same as second starter)     - 560 ohms
MUX Ignition     purple/brown     - resistor     ignition switch, black 5 pin plug, pin 2
Keysense     (same as second starter)     - 8500 ohms
CAN Bus High     white/lt. blue (Diagnostic CAN C)     data     data link connector, black 16 pin plug, pin 6
CAN Bus Low     white/dk. blue (Diagnostic CAN C)     data     data link connector, black 16 pin plug, pin 14
CAN Bus High 2     white/black (CAN C bus)     data     SKREEM around ignition switch, black 8 pin plug, pin 6
CAN Bus Low 2     white/lt. blue (CAN C bus)     data     SKREEM around ignition switch, black 8 pin plug, pin 7
CAN Bus High 3     white/gray (CAN IHS bus)     data     instrument cluster, brown 20 pin plug, pin 16
CAN Bus Low 3     white/orange (CAN IHS bus)     data     instrument cluster, brown 20 pin plug, pin 15
Power Lock     purple/lt. green     -1000 ohms     driver kick, door harness, black 14 pin plug, pin 5
Power Unlock     (same as power lock)     - 180 ohms
Lock Motor     tan/white     5 wire     driver kick, door harness, black 14 pin plug, pin 8
Driver Unlock Motor     tan/lt. green or tan/yellow     5 wire     driver kick, door harness, black 14 pin plug, pin 1
Passenger Unlock Motor     tan/brown     5 wire     passenger kick, door harness, black 14 pin plug, pin 8
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (see disarm no unlock)
Disarm No Unlock     (Sentry Key, ignition, and keysense)
Parking Lights (+)     white/orange (L); white/purple (R)     +     passenger kick, harness to rear
Parking Lights (-)     (LIN bus)
Hazards     white/dk. blue     -     hazard switch, black 8 pin plug, pin 1
Turn Signal (Left)     white/lt. green (F); white/dk. green (R)     +     turn signal light (F); passenger kick, harness to rear (R)
Turn Signal (Right)     white/tan (F); white/yellow (R)     +     turn signal light (F); passenger kick, harness to rear (R)
Headlight     white/dk. blue (L); white/orange (R)     +     headlights or underhood fuse box, green 26 pin plug, pins 3, 11
Reverse Light     white/gray     +     passenger kick, harness to rear
Left Front Door Trigger     purple     -     driver kick, door harness, black 14 pin plug, pin 4
Right Front Door Trigger     purple/white     -     passenger kick, door harness, blk 14 pin plg, pin4
Left Rear Door Trigger     purple/gray     -     passenger kick, harness to rear
Right Rear Door Trigger     purple/yellow     -     passenger kick, harness to rear
Dome Light     yellow/white     +     underdash light or passenger kick, harness to rear
Trunk/Hatch Pin     purple/orange     -     passenger kick, harness to rear
Hood Pin     purple/lt. blue     -     hood switch or underhood fuse box, gray 16 pin plug, pin 3
Trunk Release Motor     lt. green/white (unlock only)     5 wire     passenger kick, harness to rear
Tachometer     bn/yl, bn/dk bu, bn/lt bu, bn/tn, bn/og, or bn/pu     ac     any fuel injector, black 2 pin plug, pin 2
Clutch Pedal     yellow/orange (interlock); dk. green/org (upstop)          clutch switch under hood, blk 3 pin plug, pin 2, 1
Fuel Pump     dk. blue/orange     +     underhood fuse box, brown 40 pin plug, pin 10
Rear Defroster     dk. blue/white     + latched     passenger kick, harness to rear
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     (LIN bus)
Right Front Heated Seat     (LIN bus)
Speed Sense     (wheel speed sensor)
Brake Wire     white/tan     +     brake switch, gray 6 pin plug, pin 6
Parking Brake     dk. green/white     -     parking brake switch, black 1 pin plug, pin 1
Horn Trigger     gray/yellow     +     horn or underhood fuse box, green 26 pin plug, pin 18
Wipers     brown/lt. blue (LO); brown/orange (HI)     +     wiper motor or underhood fuse box, brown 40 pin plug, pins 12, 11
Left Front Window (Up/Down)     orange/lt. green - orange/white     A     front power window switch, black 14 pin plug, pins 14 - 13
Right Front Window (Up/Down)     orange/brown - orange/purple     A     front power window switch, black 14 pin plug, pins 7 - 3
Left Rear Window (Up/Down)     orange/white - orange/gray     A     front power window switch, black 14 pin plug, pins 8 - 9
Right Rear Window (Up/Down)     orange/lt. blue - orange/dk. blue     A     front power window switch, black 14 pin plug, pins 1 - 2
Radio 12V     yellow/red     +     radio, gray 22 pin plug, pin 1
Radio Ground     black     -     radio, gray 22 pin plug, pin 12
Radio Ignition     (CAN IHS bus)
Radio Illumination     (CAN IHS bus)
Factory Amp Turn-on     (CAN IHS bus)
Left Front Speaker (+/-)     gray/purple - gray/yellow     +,-     radio, gray 22 pin plug, pins 21 - 22
On models with amplifier, the speaker wires are gray/purple - gray/yellow at the amplifier under driver dash, black 16 pin plug, pins 8 - 16. The tweeter wires are gray/orange - gray/yellow at the amplifier, white 22 pin plug, pins 20 - 9.
Right Front Speaker (+/-)     dk. green/purple - dk. green/yellow     +,-     radio, gray 22 pin plug, pins 19 - 20
On models with amplifier, the speaker wires are dk. green/purple - dk. green/yellow at the amplifier under driver dash, black 16 pin plug, pins 7 - 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 - 8.
Left Rear Speaker (+/-)     gray/lt. green - gray/dk. green     +,-     radio, gray 22 pin plug, pins 8 - 9
On models with amplifier, the speaker wires are gray/lt. green - gray/dk. green at the amplifier under driver dash, black 16 pin plug, pins 13 - 5.
Right Rear Speaker (+/-)     dk. green/lt. green - dk. green/gray     +,-     radio, gray 22 pin plug, pins 10 - 11
On models with amplifier, the speaker wires are dk. green/lt. green - dk. green/gray at the amplifier under driver dash, black 16 pin plug, pins 4 - 12.
Subwoofer (+/-)     gry/brn - dk grn/brn (1); gry/wht - dk grn/wht (2)     +,-     amplifier under driver dash, black 16 pin plug, pins 14 - 6; 3 - 11
Aux. Audio Input Left (+/-)     dk. green/orange - dk. green (hands free audio)     +,-     radio, gray 10 pin plug, pins 1 - 6
Aux. Audio Input Right (+/-)     dk. green/yellow - dk. green (hands free audio)     +,-     radio, gray 10 pin plug, pins 2 - 6
Satellite Radio 12 Volts     (built into radio)
Item     Size     Depth     Location
Headunit     double DIN          center of dash
Left Front Speaker     6.5          left front dash
Left Front Tweeter     0.75          left front dash
Right Front Speaker     6.5          right front dash
Right Front Tweeter     0.75          right front dash
Left Rear Speaker     6.5          left rear roof
Right Rear Speaker     6.5          right rear roof
Subwoofer     8          right rear quarter panel
Satellite Radio Tuner     (built into radio)
Gary Sather
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
