2007 Maxima Power Mirror Wiring
harvey02
Posted: May 15, 2017 at 8:52 AM / IP Logged Link to Post Post Reply Quote harvey02
Hi, I recently stumbled upon a module that will automatically fold my power folding Mirrors on my 07 Nissan Maxima when I start or turn off my car.
Here is a similar module on Amazon:
https://www.amazon.com/dp/B01KJC7SFI/ref=cm_sw_r_cp_apa_9hrgzbD0S5MFF
I was just wondering if anyone knows the wire diagram of the folding mirror switch in the dash, as I'll need to tap into the fold/unfold wires and I don't want to fry my whole car.
Has anyone here ever done such a mod, or something similar which involved the mirror folding wires?
Thanks in advance!!
Ween
Platinum - Posts: 1,366
Posted: May 15, 2017 at 6:07 PM / IP Logged Link to Post Post Reply Quote Ween
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=142461
harvey02
Posted: May 15, 2017 at 11:40 PM / IP Logged Link to Post Post Reply Quote harvey02
Thanks so much! That was a great help!
I started wiring it, and got a little stuck.
My module has one wire to open the mirrors, and one wire to close it.
From the wiring diagram you posted it looks like there are two wires to open and two wires to close.
Should I attach both opening wires to the one on the module, and both closing wires to the one on the module? I don't want to short anything out.
(I already tried using only pin 8 and pin 11 and it doesn't work properly).
Thanks!!
harvey02
Posted: May 16, 2017 at 4:15 PM / IP Logged Link to Post Post Reply Quote harvey02
Ended up connecting both wires from the car harness to the single wire on the modules harness and it works properly.
harvey02
Posted: May 17, 2017 at 8:19 PM / IP Logged Link to Post Post Reply Quote harvey02
Update: After actually using the car I noticed that it doesn't work properly.
When the car is off and I unlock and lock, the module works properly and opens/closes the mirrors.
But when the car is on, the mirrors automatically close. Not sure what the problem is...
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
